First post, by PhilsComputerLab
- l33t++
So I've tried a GeForce256 on a fast Pentium 4 and it turns out that the TnL engine is actually holding the graphics card back. In 3DMark for example you can configure to use TnL or do it on the CPU. When you run it on the CPU the scores are higher, this is also with games that have the option (MDK 2 for example).
But is there an easy way to turn the TnL engine off? I had a look in the driver but couldn't find anything. Maybe a registry setting or some other tool?
