Reply 20 of 25, by Bossman
- Newbie
wrote:Remember of the cacheable RAM of super-socket 7 boards: […]
wrote:+ Asus P5A ATX Motherboard
+ 512MB of RAM (2x256MB PC100 SDRAM)Remember of the cacheable RAM of super-socket 7 boards:
When you have for example, the ALI Aladdin V chipset (D and E) with revision up to 1.04 of Asus P5A has only 128MB cacheable!!!
If you have may revision 1.05 or 1.06 , then there is no issue with 512MB.http://www.amd-k6.com/cacheable-ram-on-socket-7-platforms/
Test from anandtech:
"Unfortunately, the current design of the ALi Aladdin V Chipset only allows for the first 128MB of RAM to be cached, meaning anything above that would end up slowing you down more than it could possible speed you up. "
http://www.anandtech.com/show/116Edit:
Yes ,sorry , you have the + version of K6-2/3, then everything is alright, limit is 4GB...
My mobo/cpu combo is the Asus P3B-F 1.04 and a PIII 550mhz slot 1. Not sure what the above has to do with my setup?
