First post, by Tsukiouji
I've got that CPU with glued heatsink and couldn't identify it first, but it just worked, so I convienced myself that there's no need to detach that heatsink. Later as I switched 486 CPUs between my mo-bos this little fellow happend to be placed right after the DX2 in a than-unused mobo. Today I've powered that rig and found it working fine, and what is more interesting, it even passes tests with results comparable to DX2/66. I got curious what's under the heatsink (like, maybe SL-enhanced pard, or something), finally got it off, and literally was stunned - a plain old DX/33. Curiously, it looks like SX829 is the latest stepping for DX/33s: http://www.cpu-world.com/sspec/SX/SX829.html .
Even more interesting fact, as I first tried to identify the chip by it's markings underneath, i've stumbled upon a collector here: https://sites.google.com/site/alexanderhere/collections . He posses an i486 A88486DX-50 with quite similar markings underneath 'A4 ED 38' and, i'd say, a very close number of 93292384CB.
    934.07 KiB
    91.85 KiB
Reply 1 of 3, by BSA Starfire
Intel had a habit of under marking CPU's to fill market gaps after they had mastered the process of chips to fill the market. Perhaps your chip is one of these. It was always common to find 486 SX 25MHz that would run at 33MHz or more for example.
Reply 3 of 3, by Tsukiouji
Welp. I've always thought that clock doubling was made internally and kind of hardlocked. Never ever crossed my mind the very possibility of the 486DX to run at double clocks, and DX2 at triple.
