Reply 20 of 66, by Jo22
- l33t++
Ah, okay. Was just asking because WFW 3.11 had it's own VFAT filesystem driver which could cause trouble with DOS 7.1 FAT16+long filenames or FAT32.
The update for Windows 3.1 wasn't really advertised and I think both 3.10 and 3.11 had the same splash screen.
You can check the version in program manager in the about dialog. Anyway, it's not WFW so VFAT shouldn't be the issue.
And since standard mode is also affected, this error isn't caused by the Fastdisk driver.
I'm really curious what's the issue here! Haven't seen that error back in the day.
Perhaps you're running any of those DMA drivers from FreeDOS ?
Or any kind of disk overlay drivers ?
If not, maybe this issue is somehow related to the A20 gate (because doom2 "fixed" this error).
Please try himem.sys with a different machine type, like himem.sys /machine:at2
You can also add the /cpuclock:on parameter when your computer reacts somehow jerky.
Oh, and please also try this with the old himem.sys in your Windows directory if it doesn't work with newer one.
If that still doesn't help, change the setting "A20 Gate=FAST" to "A20 Gate=Normal" in your CMOS setup utility (can be found in the advanced menu).
Edit: I forgot the most obvious thing! It's also possible to create a bootlog file during start up.
Run Windows with Win /B and you will get a bootlog.txt. Would be interessting to see at which point the error occurs..
