Reply 20 of 25, by brostenen
- l33t++
wrote:Good to hear that it's working now. Out of curiosity, when you were choosing type 47, you were setting the correct drive parameters as values, right?
Well.... This is the strange part of it. There is no place in wich the parameters can be entered.
It is only the type numbers that can be entered, from 1 to 47.
I need to clear up how I am entering the BIOS. It is through an setup disk, much like old IBM's.
I think they are called IBM referance disk or something.
When I have entered the changes to the BIOS, I need to exit the program, using a menuitem.
Then it will write the changes to both the BIOS and for setting up the rest of the system.
In this disk, there are even a copy of MS Dos 3.3 and the head parking tool.
Guess the parking-tool are designed for MFM/RLL disks and the really early IDE disk's.
You can even use the system installer disk to lowlevel format a harddrive.
Well... No settings for any parameters on an Unisys PW/2 Series 300 computer.
Eighter it will autodetect heads, cylinders and such, or it is dependant on a controller BIOS.
I need to find a new BIOS battery now (3.6volt) and I need to max the mem and install a soundcard.
I think the BIOS disk "spoke" of 4mb max, just not shure if this requires a ISA-Card solution or not.
