First post, by Errius
Hello, I'm trying to get WFW 3.11 running on an old Pentium Pro system, without success. MS-DOS 6.22. It just hangs on the splash screen.
I've tried:
- Disabling all sound/networking drivers (in both DOS and the Windows installer)
- Physically limiting system memory to 128 MB
- Physically removing all expansion cards
I've tried installing from floppies and also from the Windows NT 3.51 CD-ROM, with same result.
Has anyone else had this problem?
Is this too much voodoo?
Reply 2 of 11, by Errius
Using default VGA drivers. I've tried the following cards, all with the same result:
- Integrated ATI mach64 (1 MB)
- Matrox Millennium PCI (4 MB)
Reply 3 of 11, by tikoellner
There could be something messed up in system.ini file, maybe related to soundcards you have installed (I have experienced similar problems due to some GUS referrences in system.ini). Not sure, though.
Reply 4 of 11, by Jo22
Yes, something similar. One of my Compaq laptops is not compatible with WfW 3.11.
After the spash screen, when program manager is loaded, it just freezes.
Windows 3.1, however, runs without any problems.
Reply 5 of 11, by Errius
OK I got it to run with the /D:V compatibility option:
Specifies that the ROM routine will handle interrupts from the hard disk controller
What does this mean?
Reply 8 of 11, by tayyare
"Win /n
This switch starts Windows for Workgroups 3.11 with no Windows protect mode network drivers loaded. It is useful if you think one of the network drivers is causing your problem. You might also use this switch if you are using a portable computer when is not hooked up to a network card. "
If you have enabled networking, and you are not plugged into a network, Windows for Workgroups refuses to start, and hangs on at splash screen. Your problem might be that.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 9 of 11, by Errius
Hi. No it's something to do with the hard disk:
http://windowsfaq-wiki.com/Hard_Drives_That_R … SYSTEM_INI.html
Adding VirtualHDIRQ=off to [386Enh] has fixed it. Apparently I have a non-standard hard disk (IBM DNES-309170)
