Oldskoolmaniac wrote:Pros: Very good performance with windows xp, it does have decent overclocking p4 3.4GHz @ 3.84GHz stable
Cons: Very bad 9x support, Bios updates are not existent cause Asus decided to end this board very fast in favor of the deluxe board also discussed in other forums on that note good luck finding a newer bios.
This is wrong. There are not two different boards. There is only one board known as P4P800-E Deluxe, which is sometimes referred to just as P4P800-E (including on the PCB itself). This is the second time recently I see this misinformation posted. I have been keeping track of ASUS's 865PE/875P boards, owned a couple myself, read about them extensively at the time they were relevant, and not once found any evidence of there being two different boards in the P4P800-E line-up. Either post some evidence that will surprise us all (and I will eat my laptop for being wrong), or correct the post, please. 😀
Oldskoolmaniac wrote:Yea i think im going to change my rating after the nightmare i had with it and your right 2 stars tops.
Could you share some information on that nightmare in your original post? Is it just because it does not have what you define to be good Win9x support? Because as it is, it seems that you are giving it a bad review because someone else told you it was bad. That is not how these things are supposed to work, I think. We should each rate things based on our own personal experiences.
kanecvr wrote:Please, please don't give this thing a 5 star rating. The P4P800 line is HORRIBLY unreliable. They will die for no reason whatsoever - one minute it's working, you restart your PC and it's dead. Others pop mosfets when using anything faster then a 2.8Ghz northwood. I literally had a box filled with dead P4P800-X, P4P800 Deluxe, P4P800-SE and P4P800-MX boards - all dead. Most recently I got a never opened, new in box P4P800-X - it worked for exactly 1 hour. I installed windows, installed the video card driver, restarted the PC and it died.
Is it you who we had a long technical conversation about the reliability of the P4P800 series, based on statistics? I don't remember. I cannot argue with your numbers, though I have to wonder if perhaps the sampling is skewed due to there maybe being more ASUS boards in the wild than other brands (in many parts of the world they had been the #1 most popular brand at the time, and not only then).
My personal experience is far more modest, but more positive; it included a P4P800-E that ran for ~8 years with a 3GHz CPU with no issues, until it started succumbing to age (which is quite reasonable for a board, even if some last longer). It was replaced with another used P4P800-E which only lasted for 1-2 years, but that may be due to physical deformation (I only later noticed that it was warped around the socket). Now that system hosts a P4C800-E.
kanecvr wrote:The P4C800 based on the i875 is another story altogether. Those deserve 4.5 to 5 stars.
It's really hard to do an accurate evaluation of these claims, since there were so many different flavors of P4P800/P4C800, and sometimes multiple revisions of the same board. I find it generally possible that certain flaws were fixed, and maybe others introduced between revisions. It is also theoretically possible that with the P4C being the flagship, ASUS used slightly better materials / processes / testing compared to the P4P, although I doubt it, since it's basically the same board, and what makes it flagship and premium and pricy is the Intel 875P chipset versus 865PE.
For example, a lot has been said about the faults in the the ESD tolerance on the ICH5/ICH5R USB controllers (coupled with ASUS's possibly poor implementation) causing southbridges to blow when things are connected to improperly grounded front panel USB ports. The same ICH is used on the P4P and P4C series, so I don't know why this fault should be more common on one than on the other. Although maybe it is? Is there any explanation to that?
Carlos S. M. wrote:The P4P800 now doesn't POST at all without beeps and making some whistle noises, i also saw a bad cap near the northbrige.
If you see a bad cap, this is already good. 😀 Most of them fail without any bad caps or visible signs of damage, and go figure out which component went bad.
Carlos S. M. wrote:one question, only the just P4P800 series are affeected or does more i865 series ASUS mobos are affected as like like the P5P800 series and the ASUS P5PE-VM (LGA 775 versions)? i had also an ASUS P5PE-VM dying for without reason
All boards can fail without reason. I had a new Gigabyte G41M-ES2L die electrically during normal work on the first day of operation. That does not mean it is necessarily a common fault; a sample size of 1 means nothing. The replacement G41M-ES2L I got has been working for several years in the same system without a single hiccup...
