First post, by Elia1995
Hello, people of Vogons !!!
Today I bought a MIDI cable (round in and out to gameport) so I can connect my MIDI keyboard to my sound cards with a gameport, I tried it on the Sound Blaster CT2950 in my 486SX2 Olivetti M4 434S. I can play .mid MIDI files with MegaMid without issues and some sound even better than the FM synth of the sound card (notice: I'm just using a MIDI keyboard and NOT a MIDI module like an MT-32 or SC-55 yet !!!), but when I try to use the "General MIDI" option in games, after I select "save & run" in the setup, the whole PC starts to struggle and lag, the games barely start and I hear nothing at all... what's wrong ? It can play .mid files with MegaMid and can't play MIDI music from the games engines ? 😕
I only tried with Raptor and Doom and it does the exact same thing with both games... well, Doom already lags on its own on the 486, but it's playable, now it takes up to 2 entire minutes to just make the "Ultimate Doom" picture appear with General MIDI in the configuration. I do not think that it's due of the MIDI device being a keyboard and not a MIDI module, as the sound card doesn't care what's connected to it as long as it is a MIDI device that can play sounds.
According to Google, I'm the only person that's having this issue...
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 1 of 41, by PhilsComputerLab
I believe MIDI IN is causing this.
Unplug MIDI IN coming from the keyboard, and the games should work smoothly (only use MIDI OUT coming out of the Sound BlasteR).
YouTube, Facebook, Website
Reply 2 of 41, by Elia1995
I connected the cable that says "IN" where in the keyboard says "IN" and the one with "OUT" printed on where in the keyboard says "OUT", is it correct ?
So I have to only leave the "OUT" cable in the "OUT" slot like that ?
But that way how's the data going to be delivered to the keyboard if that's its output ("data going towards the gameport") slot ?
The keyboard is a Yamaha PSR-160, by the way.
EDIT: Just tried like that with only "OUT" in the keyboard, it still freezes the PC.
I just tried the opposite I left only the "IN" one in the keyboard and it isn't crashing anymore 😁
But now it's glitching: every time I complete a level, for example, the last note of the previous music keeps playing over the subsequent music, making an ear rape after a while, the same after I exit the game: the last note keeps playing until I restart the keyboard, that's some annoying thing 😢
Reply 3 of 41, by PhilsComputerLab
Out on a plug goes into in on a port if that makes sense 😀
It comes OUT of the sound card and IN to the MIDI module.
The Sound Blaster will cause issues in games if it receives MIDI IN. Disconnect it, just have MIDI OUT on the Sound Blaster go to MIDI IN on your MIDI module.
I take it the MIDI IN on your keyboard acts like a MIDI module, it plays music?
EDIT: Your photo doesn't help a lot 🤣 Got a wide shot of everything connected?
Reply 4 of 41, by Elia1995
OH MY GOD, the (486) PC just went nuts !!!
It began to show random pixels on Doom while the MIDI was working, then it froze, now when I power it on it does 4 beeps like that: BEEEEEEEP, BEEP BEEP BEEP and the screen looks like an ASCII canvas with the "checkerboard" ASCII symbol and the DOS cursor randomly moving around while it does the boot stuff... creepy.
Ok, sorry for the off topic (even though it's not so off topic because it has NEVER done that before playing around with MIDI), here are the pictures of how I cabled the keyboard:
right into the gameport !!!
And this is how the PC now boots and looks like after I got the MIDI to work in-game:
Fun fact: the PC isn't actually dead: it actually boots and works, I just can't see a damn thing of what I'm doing... and it has only ISA x16 slots, I have no idea what kind of graphics card I can find for it, now 😒
Here, I just ran Doom:
At least the MIDI is playing perfectly 😁 😁 😁
Reply 5 of 41, by jesolo
Unplug the MIDI cables and see if you still experience the same problem.
If not, then it's possible that, with all the plug and unplug of your MIDI cables, you accidentally loosened the monitor cable.
Try, on both ends, to unplug and plug in again the monitor cable. If your graphics card is not onboard, then you can also try to reseat it again.
Reply 6 of 41, by Elia1995
It's onboard (integrated), I'm now trying to power it on without the MIDI cable... nope, still 4 beeps...
I also tried to remove and reseat the video memory stick (I was surprised, I thought I'd find some sort of 30-pin SIMM and instead it looks like a PCI thing without the rest of the card, just a memory stick with PCI-shaped pins) but still nothing...
What the hell happened, I have absolutely no idea, how to fix it, I have no idea neither 😕
Why would MIDI interfere with the onboard graphics card ?
I read on Google that 4 beeps made of 1 longer and 3 shorter means bad video memory contact and says that the solution is to reseat/change the graphics card... but mine is onboard !!!
Look, I just made a video: https://youtu.be/i9jujiibZew?t=47
Reply 7 of 41, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Sure this is video memory, not cache? Photo of mainboard!
Either a video RAM chip is dead, or a soldering joint is open, or the video chip has damage. Try to push the chips on the mainboard while the game is running and check if it has an effect.
1+1=10
Reply 8 of 41, by Elia1995
It's this memory here, look:
13616255_10209939589755177_1005955109_o.jpg?oh=a19f261a04153a326c0660c7f0ace5ad&oe=5783F56C
How could a video RAM chip die or a soldering get off by doing absolutely nothing and just playing with the MIDI ?
Reply 9 of 41, by kixs
Are you sure this is video memory? It looks more like a cache module. Look near the VGA out connector and on the motherbord there should be a video chip and close to it, video memory chips. Usually they are soldered or in brown sockets. But it depends on the motherboard.
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 10 of 41, by clueless1
Is there a missing memory chip on that stick?
edit: maybe not. I don't see solder pads where the chip would be. Have you tried removing the module and cleaning the contacts? Maybe it's just a coincidence that the issue started while you were experimenting with the MIDI.
Reply 11 of 41, by Jo22
Uhm, maybe it's an IRQ conflict ?
The MPU401 sometimes uses IRQ9 (or IRQ2). And VGA also uses sometimes IRQ9 (or IRQ2)..
(Note: IRQ2 and IRQ9 are cascaded on +286 PCs.
Which means in simple words: IRQ2 is used to access the second programmable interrupt controller (PIC, i8259).
Whenever something wants to talk to IRQ2 it is redirected to IRQ9. That's why they're sometimes called IRQ2/9.
This is quite confusing whenever you use old devices made for PC/XT bus (8bit ISA), because they are unaware of IRQ9.
And because IRQ2 is free on 8088 PCs. So having a VGA/EGA card on IRQ2 and a MPU401 on IRQ9 is quite troublesome.)
More about this stuff can be read here (see "IRQ2/IRQ9 Redirection") and here .
IRQ 9 - FREE (VGA vertical sync interrupt if enabled)
Note: IRQ 9 is used on some video cards for the "vertical retrace"
interrupt. This interrupt would have been handy for things like
video games, as it occurs exactly once per screen refresh, but
unfortunately IBM cancelled this feature starting with the original
VGA and thus many VGA/SVGA cards do not support it. For this
reason, no modern software uses this interrupt and it can almost
always be safely disabled, if your video card supports it at all.
If your card for some reason CANNOT disable this IRQ (usually there
is a jumper), one solution would be to clip the printed circuit
contact on the board: it's the fourth contact from the left on the
back side. I take no responsibility if you try this.
- Avery's favourite: IRQ2 (actually IRQ9). Watch that VGA, though.
Source: http://apenwarr.ca/arcnet/howto/cards.html
By default, the MPU-401 uses IRQ #9, although modern versions have jumpers for setting IRQ).
Whenever the MPU receives an incoming MIDI byte, it will interrupt the computer.
In your interrupt handler, you should keep reading bytes from DATA port while DSR is low.
Source: http://www.piclist.com/techref/io/serial/midi/mpu.html
Another problem is the ACPI's System Control Interrupt (SCI). It is also using IRQ9. 🙁
Reply 12 of 41, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
In DOS the VGA card doesn't use interrupts - except for one or two demoscene products. The corruption on the screen is not IRQ related.
Getting warm, cold, warm, cold can eventually make production flaws surface. And you were working on it - the force from inserting the cards may have given the damaged part the rest. Or it was just coincidence.
Please make a picture of the whole board. Then we see what belongs to the video controller.
1+1=10
Reply 13 of 41, by Elia1995
Ok, here are some pictures.
This is the "graphics card", I believe it's it because it says "Cirrus Logic" on the chip.
This is the 14-pin VGA connector
And this is pretty much the whole area of the motherboard with the chips and jumpers, there is a blue jumper near the GPU, as I have highlighted it
Maybe I'll now change the title of the thread because it's becoming something else than just the MIDI issue 🤣
Reply 14 of 41, by xjas
You didn't "hot plug" the MIDI connector did you? (Plug or unplug it while the system is on.) That thing carries a nontrivial voltage - it's vaguely possible that a power spike could have done some damage, but 99.9% of the time this would be to some component on the sound card or keyboard. Actually I'm hard-pressed to imagine that could take out a Vram chip, but you never know.
Reply 15 of 41, by Elia1995
No, I've never unplugged the MIDI cable from the sound card at all.
The sound card is even still working fine, I can still hear both MIDI music and game sounds… it's just unpleasant to the eyes !!! D:
Will a VLB graphics card fix it ?
Reply 16 of 41, by matze79
Looks like defective Memory/DAC.
Reply 17 of 41, by Elia1995
Today somehow I got it to show something better at boot… and then returned like that… hmmmm
Reply 18 of 41, by clueless1
Why not take the system apart, clean it (remove all the dust that is seen in the photos), clean all contacts (RAM, expansion cards, CPU) with 90% alcohol, basically give it a good detail, then put it all back together and see if it's any better. You've got nothing to lose by trying. While it's all apart, it will be easier to photograph and examine for any other clues.
Reply 19 of 41, by Elia1995
I'll try, after all a good cleaning would be nice
