First post, by bjt
My Athlon machine runs a Vortex 2 under Win98. It works great with A3D games.
I have a spare Audigy 2 ZS, could I put this in too for better EAX support?
Reply 1 of 5, by Darkman
sure you could, just be careful of resource conflicts (Ive had that problem)
the bigger annoyance is getting the Audigy 2 ZS to work properly on Win98 , its not impossible, but it is a hassle.
Reply 2 of 5, by Stretch
I use hardware profiles for my 3 sound cards.
Profile 1: Vortex 2 - Yamaha and Audigy 2 disabled in device manager
Profile 2: Yamaha - Vortex 2 and Audigy 2 disabled in device manager
Profile 3: Audigy 2 - Vortex 2 and Yamaha disabled in device manager
Then I swap the a3d.dll based on the profile I select.
Win10 - AMD Ryzen 9 3900 - 16 GB - GeForce RTX 2060S - Sound BlasterX AE5-Plus
Win98SE - ASRock 775i65G R3.0 - Celeron 2.2 GHz - 2 GB - GeForce FX5700 - Audigy 2 ZS
Win98SE - Via Apollo Pro Mobo - Pentium II 233 - 256 MB - Voodoo 3 1000 - Yamaha YMF724
Reply 4 of 5, by Darkman
bjt wrote:
Please elaborate 😀
by default the installation for the Audigy2 ZS installs the WDM drivers , which don't work as well as the more standard VxD drivers you tend to find on Win9x.
the VxD drivers are there but its a bit of a process to get them going.
an SBLive or Audigy1 won't have those issues.
Reply 5 of 5, by bjt
OK! I managed to get this working fine, I think.
Resource conflicts weren't a problem, the Audigy 2 took IRQ 3 which was free as I only have one serial port.
However, when running CTZAP from the Audigy2 ZS disc, the install VxD option was greyed out.
Using the vanilla Audigy2 disc, the VxD option was available and installed fine. Tested EAX in Diablo 2, seems to work.
Interestingly, the main installer on both the Audigy2 and ZS discs say they can't find the Audigy2 hardware. Only running CTZAP directly works.
That means I have to install the applications individually from the CD, no big deal.
Now running Ti4200/V3k 2000/Aureal 2 and Audigy 2 in this Win98SE machine, all bases covered for Gfx and Sound!
