First post, by mkubiak402
Hi my name is Matthew i am new to this forum I just got my retro PC Done and LOVE IT! it has been rock solid even in the late 90's i don't remember my PC running like this 🤣 i remember having drivers trouble or hard ware just not liking each other. but this system just works and works well
Me and a friend of mine have been working to remake the PC we had in high school with some stile upgrades so fare we have been having a ton of fun even playing Diablo 1 and Quake III arena through the modem even had my wife pic up the phone on me as i was playing Fun times...
one thing i am having trouble with i have a copy of Diablo II with a real KEY my CD's where messed up so i remade some from ISO images i have on my backup server but i cant get the game to works it keeps asking for the play disk...?
System specs
Windows 98se
MSI MS5169 ALi Aladdin V Chipset
AMD K6-III+ 450 @ 500Mhz had it to 600Mhz but did not see any boost so i left it at 500
Modified socked A CPU cooler to fit socket 7 MAX cooling
384Mg PC 100 Ram
Voodoo 5 5500
Sound Blaster 16
20Gb and 40 Gb WD hard Drive
Sony CD/DVD was swapped in after the pic was taken
DOS 6.22 FIC-486-VIP-IO AM486-DX2 66Mhz 64mg
Win98se MS-5169 AMD K6-III+ 450 @ 550Mhz 512mg Voodoo 5 5500.
Win98se GA-6VXE7+ Intel Pentium III 750 512mg Voodoo 5 5500.
Win XP MS-6712 AMD Athlon Xp 2700+ 2gb 6600GT
Reply 1 of 24, by clueless1
Welcome, loved your photos. Very nice PC. I especially like that you and your friend are using real dial-up modems to play online. 😀 Nice touch, having your wife pick up the phone line while you're playing. 🤣.
Reply 2 of 24, by brostenen
Welcome. And that is a nice system. The only question that comes to my mind, are about the chipset.
What revision is it and can it cache all that ram?
About Diablo. If the ISO's are a copy of you'r original disc, then Diablo will ask for a original pressed disc.
If you try to use a direct copy of the original pressed disc, it will not read that.
Reply 3 of 24, by mkubiak402
brostenen wrote:
Welcome. And that is a nice system. The only question that comes to my mind, are about the chipset. What revision is it and can […]
Is there a tool to fined out what rev the chip set ver it has? the north bridge has a cooler on it or a tool to fined out if it is cashing all the ram? i did update to the newest Bios they had on the MSI web page..
the motherboard is ver 4 AL9 "south bridge is A1"
it is reporting the motherboard wrong.... as an FIC it is not 🤣
Reply 4 of 24, by brostenen
It is written on the chips.... I have found some good reading on MVP3 and ALI-V ragarding cacheable Ram.
http://www.amd-k6.com/cacheable-ram-on-socket-7-platforms/
Reply 5 of 24, by mkubiak402
well is my haste i glued a cooler on the north bridge ill have to dig there may be a pic of it before it was covered up.... 🙁
ok unless i am reading this wrong i have the K6-III+ and i am ok it will cash all the ram i have installed..
Reply 6 of 24, by Tetrium
mkubiak402 wrote:
well is my haste
Haste + retrocomputing == *Wheres the trouble* 🤣
But anyway, nice rig you got there.
Just a few things I did notice:
- K6-III is not the same as K6-III+, except when running at the same speed. Just a minor thing here, but it can make a difference in some cases.
- Your ATX case is one of the earliest ones, build for Slotted boards mostly. The fan of your PSU and the fan of your CPU HSF will compete for air as they will probably be trying to pull air from different directions.
With a K6-III+ combines with such beefy cooling, this probably won't be noticeable, but cases like yours are probably best reserved for slotted boards.
My retro rigs (old topic)
Report spammers here!
Reply 7 of 24, by candle_86
Tetrium wrote:
Haste + retrocomputing == *Wheres the trouble* lol […]
mkubiak402 wrote:
well is my haste
Can be gotten around with a little cardboard, make a little duct for the cpu fan
Reply 8 of 24, by mkubiak402
there is no vents on the other side of the PSU and more then enough room the cooler never gets hot any how
but if i have to i would try flipping the fan to suck and push to the PSU...
Reply 9 of 24, by mkubiak402
all so working on a Pentium pro system i may scrap it and sell off the parts... 🙁
and have this motherboard i do have 2 CPUs with it just 1 was installed i did not have the sec cooler at the time...
Reply 10 of 24, by FFXIhealer
mkubiak402 wrote:
http://i190.photobucket.com/albums/z172/mkubiak402/electronics/20160717_133238_zps7wvrj3d2.jpg […]
OMG, the feels!!!! I had that exact CD-Writer drive back in my Pentium II PC days. I almost miss it! Brings a tear to my eyes thinking about it! The nostalgia! That was a very good burner in its day.
Reply 11 of 24, by mkubiak402
FFXIhealer wrote:
it is a solid CD burner drive opens and closes but i needed a DVD drive 🙁
Reply 12 of 24, by mkubiak402
funny thing is one of my other friends is like "why even build that computer you can just run in on a new system"
i was like well what the hell is the fun in that now? this why everything is compatible and will work and you not messing with a DOS box or trying to get old windows 98 games to work... even harder when your running a 64bit os and windows 10..
Reply 13 of 24, by brostenen
Yes.... And he will say it untill he have seen enough people run the old games.
Then he will realize how hard it is, and he will be pointed to Vogons. 🤣
Reply 14 of 24, by luckybob
But seriously, if you decide to let those 2 motherboards go, let me know. We can work something out.
Reply 18 of 24, by luckybob
SPBHM wrote:
is it wrong that I like the Pentium Pro a lot more than the K6 III?
Absolutely not. The 1mb pentium pro cost $2700 each if you bought 1000. Accounting for inflation, that ~$4000 US today. Plus they are pretty and gold. And you can run then in 2, 4, & 6-way setups. Hell, in today's market the 333mhz overdrive commands a VERY hefty price premium. I dare say its worth 2x the K6-3.
That said, the K6 has its merits, just not in my eyes.
Reply 19 of 24, by mkubiak402
yes i need to fined some sweet case badges for it. some 3dfx voodoo and AMD case badges would look nice!
for how much you paid for the 200Mhz 1mg cash vers of the Pentium pro they put it in a cheep package the thin aluminum heat spreader they have on it is week and will warp when there is to much heat i had 2 that where warped and no longer working.
The only thing holding me back form completing the Pentium Pro is the lack of AGP video the only video card i have for it is a ATI 9100 and driver support for it SUCKS! all most every game i try tells me there is no 3d accelerator and i cant run NT4.0 at all with that card no drivers 🙁 and windows 2000 seems to be running slow ish...
i don't know what i want to do with it yet i love the ida of having one of them running is nice.. I was going to have it run a PFsense but the OS will not install... so i have to shop for the fasts PCI card i can fined but there $$$$ on Ebay...
i had a chance to get a matched par for Pentium II over driver 333 5 years a go for $120 😠
