First post, by Rabanik
Hi guys.
I have an industrial mobo iBASE MB865-R and my secondary graphic card is 3dfx Voodoo 5 5500 (flashed MAC version) which does not work there. My primary graphic card is XTX GeForce 7800 GS AGP 256MB. There is an integrated VGA on this motherboard too and when I set whatever (init PCI first, disable VGA) in BIOS nothing helps. AGP card is preffered by BIOS on the first place even I enable VGA in BIOS. When I pull out all graphic card and disable VGA in BIOS system after boot beeps because it did not find any graphic card. I tried to disable VGA in BIOS and I pulled out the GeForce so V5 was the only card in the PCI slot and system beeps too. I have tried put V5 into the every PCI slot and the same result. So I am pretty sure that this mobo MB865 does not support any other PCI graphic card. Can you help me with it please? V5 works great in another computer of course. Any suggestions? There is no problem with a voltage like 3.3V required instead of 1.5V for newer AGP slot. This card is the PCI one. This must works in every computer. I think I need some guy who knows how to moddify the BIOS. Thank you.
