First post, by CheeseMeister
So I have a ZEOS Pantera motherboard with a Pentium CPU inside, super eager to test it but I haven't even been able to turn it on yet. It takes an AT power supply which I didn't have one spare at the time.
I managed to get one that was still factory sealed off of eBay, manufacturer's date says 2002 which is cool. But I'm wiring it up and suddenly I realise I don't have enough 6 pin connectors for the board. It seems two 6 pin connectors was pretty standard, they're called P8 & P9 since they have different wiring,
However according to the documentation it takes an extra connector (possibly called a P10), the manual calls it a 3v AUX connector. Also 6 pin as I say.
Now I have no idea what to do, and I don't especially want this new PSU to be useless. Does anyone know where to buy like a molex to 3v AUX 6pin adapter? It's hard to find because google keeps throwing PCI-E 6 pins up in the results.
If it's not available does anyone on here think they could wire one up for me? Is that even possible? I'm not good with wiring and soldering. I could kick you some monies.
Any and all advice welcome, much thanks in advance
