Reply 41 of 54, by clueless1
- l33t
Malware...whether virus or rootkit, who knows? Glad you got it figured out though!
Whatever media you used to install the infected DOS needs to be doused in lighter fluid and made into a bonfire.
Reply 42 of 54, by xstraski
Thanks a lot, really.
Hey, where exactly such viruses can "live" except HDD in 486 systems?
Can they "save" their code somewhere in CMOS or something like that?
Reply 43 of 54, by clueless1
- l33t
Master boot record. That would be a rootkit.
Reply 44 of 54, by darry
Just an idea, but 6KB sounds like about the ballpark RAM usage for a drive overlay . Could it be that possible that the drive you were previously has a rather buggy one ?
Reply 45 of 54, by Jorpho
- l33t++
wrote:Master boot record. That would be a rootkit.
To be clear, no one called it a "rootkit" back in the day; the concept in general doesn't really seem suited to a single-tasking OS like MS-DOS. I would just call it a boot sector virus.
Generally such things can be safely and quickly disposed of by running "fdisk /mbr", which rewrites the master boot record. I suppose there could be viruses that detect when something is trying to rewrite the boot record, or that infect fdisk.exe. Seems unlikely, though.
Back in the day, there was at least one virus that could potentially attack the BIOS, but there's no way a copy of the virus could actually get stored there.
Reply 46 of 54, by SquallStrife
- l33t
wrote:Just an idea, but 6KB sounds like about the ballpark RAM usage for a drive overlay . Could it be that possible that the drive you were previously has a rather buggy one ?
This.
I was using EZ-Drive on my previous 486 build. When I upgraded to a PCI 486 board with a 5x86, I didn't bother to remove the overlay because "if it's working, don't fuck with it."
About a year later, I tried to play Space Quest 6, specifically the Windows version. I had no end of problems. Video for Windows would crash, INSTALL.EXE would crash, the game would install but crash on trying to run (and after such a crash, no other program would launch until you rebooted).
I tried swapping video cards, thinking later drivers could contain Pentium-specific instructions. I tried swapping RAM, sound cards, CPUs, you name it.
In a final act of desperation, I did a complete FDISK /MBR, repartition, reformat, and reinstall. POOF. Problem solved.
Reply 47 of 54, by clueless1
- l33t
wrote:wrote:Master boot record. That would be a rootkit.
Good point. Didn't many BIOSes have Boot Sector Virus detection built into them as a consequence? I seem to remember that being a common BIOS option for quite awhile starting in the mid-to-late 90s.
Reply 48 of 54, by keenerb
wrote:This. […]
This.
I seem to recall seeing similar behaviour a few times when I migrated a hard disk from a system where I manually entered C/H/S and brought it up in a system that auto-detected it. A difference in the specified settings caused a lot of weird errors.
Reply 49 of 54, by Jorpho
- l33t++
wrote:Didn't many BIOSes have Boot Sector Virus detection built into them as a consequence? I seem to remember that being a common BIOS option for quite awhile starting in the mid-to-late 90s.
There was something called "ChipAwayVirus", but I was never particularly clear as to what good it actually did. (If it was particularly effective, I would have expected it to be more widespread.)
Reply 50 of 54, by clueless1
- l33t
I think what the BIOS virus protection option did was write-protect the boot sector, but I think it got in the way of people doing clean installs or setting up a multi-boot system, so they disabled the option by default, then eventually got rid of it.
Reply 51 of 54, by xstraski
wrote:I think what the BIOS virus protection option did was write-protect the boot sector, but I think it got in the way of people doing clean installs or setting up a multi-boot system, so they disabled the option by default, then eventually got rid of it.
Interesting. I was always wonder what this "BIOS virus protection" option exactly does.
btw "FDISK /MBR" command in MS-DOS 6.22 / Win98SE installation boot does nothing.
I've cleaned my MBR using this:
C:\> debug
-F 9000:0 L 200 0
-a
0C5A:0100 Mov dx,9000
0C5A:0103 Mov es,dx
0C5A:0105 Xor bx,bx
0C5A:0107 Mov cx,0001
0C5A:0109 Mov dx,0080
0C5A:010A Mov ax,0301
0C5A:010D Int 13
0C5A:0110 Int 20
<press Enter twice>
-u 100 L 12 <check the code matches the above>
-g <executes>
Program terminated normally
-quit
Reply 52 of 54, by clueless1
- l33t
What do those debug commands do? I mean, what are those commands doing specifically?
Reply 53 of 54, by SquallStrife
- l33t
wrote:btw "FDISK /MBR" command in MS-DOS 6.22 / Win98SE installation boot does nothing.
Nonsense.
Reply 54 of 54, by Jorpho
- l33t++
It doesn't produce a visible result on the command line, if that's what you mean. But it definitely does something.
I've cleaned my MBR using this: […]
C:\> debug
-F 9000:0 L 200 0
-a
0C5A:0103 Mov es,dx
0C5A:0105 Xor bx,bx
0C5A:010D Int 13
0C5A:0110 Int 20
<press Enter twice>
-g <executes>Program terminated normally
-quit
Whatever works for you, I guess, but I would be gravely concerned about mistyping a single number and torpedoing my entire disk structure.
