Reply 1 of 23, by Trank
- Member
Well a SSD doesn't have any moving parts. So is it even possible to somehow make it nosier?
Reply 2 of 23, by 386SX
wrote:Well a SSD doesn't have any moving parts. So is it even possible to somehow make it nosier?
I know, it's that I like so much both the old IDE and floppy disk sound to have. Also the 56k modem one is another sound I like! 😁
Reply 3 of 23, by clueless1
- l33t
What would happen if you plugged a PC speaker into the HDD LED header? 😀
Reply 4 of 23, by 386SX
wrote:What would happen if you plugged a PC speaker into the HDD LED header? 😀
Maybe the speaker resistance would be a problem? Or maybe the 5V ? voltage of the led would not be that good?
Reply 5 of 23, by Hu1kamania
I think the idea is to intercept the the HDD LED signal from the motherboard, and use it to prompt artificial HDD noise. 😎
Reply 6 of 23, by 386SX
wrote:wrote:Well a SSD doesn't have any moving parts. So is it even possible to somehow make it nosier?
Cause an SSD on a vintage pc is like a 1970 muscle car with a modern electric engine into it... just bad. 🤣
Reply 7 of 23, by Sammy
Some tryed to use the hdd-led (with driver circuit) as input for an Relais.
so if the Led flashes, the relay does *click click clickclickclick click click"
Reply 8 of 23, by 386SX
wrote:Some tryed to use the hdd-led (with driver circuit) as input for an Relais.
I imagined but I wanted some realistic disk sound. Maybe I will still look for some UDMA33 disks until they will run for that win9x machine.
Reply 9 of 23, by Jorpho
- l33t++
I'm not sure what exactly you could use to generate a "realistic" sound, but I do very much like the idea.
Reply 10 of 23, by Jepael
Motherboard has a current limiting resistor (because wires connect directly to LED). It is not 100% sure if the resistor is on 5V side or GND side of the pin, and if the 5V is switched on/off or the GND side. Maybe an optocoupler in place of the LED will provide isolated control with higher current drive ability.
As for the noise, how about cell phone vibration motor?
Reply 11 of 23, by Jade Falcon
BMW called, they want there idea back.
Reply 12 of 23, by stamasd
wrote:I'm not sure what exactly you could use to generate a "realistic" sound, but I do very much like the idea.
A walkman with a tape recording of a real HDD. Talk about vintage sound.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 13 of 23, by Ozzuneoj
- l33t
The immediate problem I see with simply booking up a buzzer speaker in place of an LED is that the LED is likely DC where as speakers are AC. Hooking up DC to a speaker would not be good for it, especially for prolonged periods of time. It basically just causes the speaker to "turn on" rather than move in and out like it is supposed to to generate sound.
Reply 14 of 23, by Jo22
- l33t++
wrote:Hooking up DC to a speaker would not be good for it, especially for prolonged periods of time.
That's true, but hasn't this been done already in the old days of radio (crystal radio sets, audion receivers, etc.) ?
Reply 15 of 23, by kiwa
- Newbie
it's funny, i have a weird issue with a modem and a cf card, the modem speaker makes "hard disk noises" when there is activity, i think it's cool but still a weird thing.
I made a video, probably you will need headphones to hear the noise.
https://www.youtube.com/watch?v=a2lby4p8g9A
Reply 16 of 23, by gdjacobs
- l33t++
wrote:wrote:Hooking up DC to a speaker would not be good for it, especially for prolonged periods of time.
The standard trick is to use a coupling capacitor.
Reply 17 of 23, by matze79
- l33t
Hook up a Transistor to the HDD IDE + Pin and Drive a Relay with it. Don't forget a flyback diode
Every Time a LED Blink occurs the Relay is clicking 😳
Poor Man's HDD Soundsimulator:
Arduino Relay Module 😀
Reply 18 of 23, by Jepael
wrote:wrote:wrote:Hooking up DC to a speaker would not be good for it, especially for prolonged periods of time.
Motherboard drives the PC speaker current just on and off directly without AC coupling. No smoke and flames seen yet. Of course home stereo speakers are not meant to be driven with DC.
Reply 19 of 23, by firage
- Oldbie
Anything resembling an HDD is going to require digital audio samples.
I've seen software emulators with emulated sounds for disk access before, but that's quite a bit easier to pull off than hardware.
