xjas wrote:The hardware should be fine as long as there is a way around the EFI issue.
Scali wrote:How does Bootcamp work on a Mac?
FuzzyLogic wrote:Even if you have DOS booting, it would be useless because you don't have any drivers for sound, video, or lan. VGA support is limited. You'll end up with one speedy little command.com box.
FuzzyLogic wrote:It overwrites the protective MBR on the GPT disk with a MBR that points to the legacy partitions. The CSM module uses that MBR to boot.
brostenen wrote:As far as I have heard, bootcamp need X86 cpu's.
Dominus wrote:@brostenen: the op was asking about the x86 mac minis not the ppc ones. Or did that come somewhere else up?
Scali wrote:On PowerPC Macs, you'd use VirtualPC to run DOS/Windows: https://www.microsoft.com/australia/off ... fault.aspx
Scali wrote:DOS doesn't need drivers. It accesses hardware directly.
Jo22 wrote:SoftWindows 1.0 was neat, btw. It was said to even run on Motorola 68000 machines! - I think I once read that it got a modified version of Windows 3.1, which contained a bit of 68k code in several DLLs to speed things up.
xjas wrote:As long as the video chip (Geforce Go 7300 in the case of the Apple TV) supports text mode and some basic VGA or VESA modes it seems like it would work and be a handy little thing to have.
hyoenmadan wrote:Scali wrote:DOS doesn't need drivers. It accesses hardware directly.
HAHAHAHaHaHahahaha...
Fueh... If was so easy, Marvin section wouldn't exist at all.
hyoenmadan wrote:or what is most important, APM. Without proper power management, a small machine like a Mac Mini will run very hot almost all time and probably would not last too much running in such conditions.
hyoenmadan wrote:Win3.0... Before Win3.1 there was Win3.0, on which Insigna software worked on. Older SoftPC/AT ran in older 68Ks and your could install Win3.0 on them, but wasn't a pleasant task. SoftPC/AT for the older 68Ks was optimized solely for DOS.
hyoenmadan wrote:Later SoftPC releases offered Win3.1 support, but them will not run in older 68Ks, only in the later models.
hyoenmadan wrote:SoftWindows is a PowerPC product, which has nothing to do with Motorola 68K series.
hyoenmadan wrote:About that rumor, i'm 99% sure it is false. You will see, Win3.1 codebase is 100% hand-crafted x86 assembler. System semantics and algorithms are very tied to how things are done in x86 CPUs, so porting it to an alien architecture wouldbe harder than crafting an new OS from zero. And that's exactly what MS did with NT. And ofc you can't mix 68K with x86, isn't magic you know.
hyoenmadan wrote:And ofc you can't mix 68K with x86, isn't magic you know.
Interesting. Would make sense, since they offered products for Unix driven RISC platforms. Thanks for pointing that out.hyoenmadan wrote:What is real truth is that Insignia worked closely with MS in order to create NTVDM and support DOS/Win3 apps in RISC CPUs through it. To accomplish that, NTVDM has built in a minimal SoftPC version as engine, which provides the virtual hardware environment to DOS/Win3 apps. In x86 NT NTVDM only uses peripheral and video code (while the rest runs in host as V86 task), but in RISC versions it also uses Insignia vCPU core.
hyoenmadan wrote:VESA modes are broken.
hyoenmadan wrote:HAHAHAHaHaHahahaha...
Return to General Old Hardware
Users browsing this forum: Aglenoth, Baidu [Spider], m1919 and 2 guests
