First post, by FFXIhealer
So I found this stuff and now it's got me curious if I can make something out of it. I posted in my Windows 98 thread about it, but if I actually do this build, it should get its own thread (this one). What I have found:
Micronics M55HI+ Revision B Socket 7 motherboard
Intel Pentium 200MHz SY045 FV80502200 (non MMX, 350nm, 15.5TDP)
I've been able to identify the RAM modules. They are all 8-chip 72-pin EDO DRAM modules, but only two of them are matched. The matched pair are both 4MB modules (1Mx4 chips) and the other two are both 16MB modules (4Mx4 chips). I had to look up chip spec sheets on all three modules to figure that out. So I have a possible 40 MB of RAM available. I don't know if they're good or not until I can power the system up and see.
I don't have any kind of manual for the M55HI+ board, but from the jumper settings I've been able to find on-line, all the jumpers are set correctly for the 200MHz Pentium processor at 66MHz bus speed.
The box also had a small fan on a metal heatsink for a Socket 7, so I'll have to test the fan to see if it blows, but should make for a very nice active cooler on the processor. Turns out, the metal passive heatsink tower that was on the processor was not glued on but only clipped on. I managed to remove it without damaging the clips. I also found no evidence of thermal paste having been used there at all. I cleaned the CPU's heatspreader with alcohol anyway, but it didn't really do any good. I'll be using thermal paste when I put the heatsink on.
I have 4x ISA and 4x PCI slots available. MB also has built-in audio (Sound Blaster 16) and IDE ports. So I'm thinking I don't have to worry about sound, just get the drivers working. All I really need is some form of storage device that will work in Windows 95 and a video output solution. Since at 200Mhz, a Voodoo1 would run screaming fast, that's probably what I'll do as a 3D accelerator. Someone in the other thread suggested an S3 Trio. Might be a good 2D card for Windows 95, don't know.
Anyway, ideas? Discuss. What would you do if you had this stuff and were in this position (i.e. no MB manual, unfamiliar with the board, no voltage module for the MB, unknown RAM, etc.)
Note: Yes, I do have a copy of Windows 95 on CD-ROM and I have a Windows 98 boot floppy.
