Looking for BIOS image for ASUS ISA 386C
Discussion about old PC hardware.
Postby BreakPoint » 2016-10-03 @ 17:30
Found this nice board but unfortunately BIOS chip missing.
Does anyone have this BIOS of know where to find it.
My CPU collection - http://cpu.f5soft.com
User avatar
BreakPoint
Re: Looking for BIOS image for ASUS ISA 386C
Postby nemail » 2016-10-03 @ 20:40
i have a working isa 386c. "anonymous coward" is also waiting for a bios dump from that board.
i'll try to get the image in the next few days...
nemail
Postby Anonymous Coward » 2016-10-03 @ 23:26
: D thanks
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby BreakPoint » 2016-10-07 @ 08:19
nemail wrote:i'll try to get the image in the next few days...
would be nice - thanks
User avatar
BreakPoint
Postby nemail » 2016-10-17 @ 16:55
Hi
here's the BIOS, I hope I extracted it the right way. I used this guide:
http://www.mess.org/dumping/dump_bios_using_debug
FINAL.txt
(64 KiB) Downloaded 41 times
nemail
Postby Anonymous Coward » 2016-10-17 @ 23:58
This BIOS recognises 4MB density SIMMs. Double plus good.
User avatar
Anonymous Coward
Postby BreakPoint » 2018-3-08 @ 12:39
Anonymous Coward wrote:This BIOS recognises 4MB density SIMMs. Double plus good.
Hi Anonymous Coward
Have you tried this BIOS? Did it work?
I failed 8 times with different EPROMs.
User avatar
BreakPoint
Postby Anonymous Coward » 2018-3-08 @ 13:01
I don't actually have an Asus 386C. I have a very similar board that has an older BIOS that I was trying to upgrade, but unfortunately it didn't work as my chipset revision is too old. I was able to determine support for 4MB SIMMs by examining the BIOS in a hex editor.
User avatar
Anonymous Coward
Postby SteliosG » 2019-2-08 @ 03:28
So , do we have the BIOS available ?
Bios date is 5/5/91
The one uploaded in this thread doesn't work .
PS . I just corrupted mine . I wanted to extract the bios and upload it here but something went terribly wrong . :(
SteliosG
Postby jesolo » 2019-2-08 @ 08:47
Use Navrátil Software System Information (NSSI) to extract the system BIOS - http://www.navsoft.cz/products.htm
User avatar
jesolo
Postby Anonymous Coward » 2019-2-08 @ 10:58
SteliosG wrote:The one uploaded in this thread doesn't work .
Why do you think that is? Corruption? On visual inspection I didn't see anything out of the ordinary.
User avatar
Anonymous Coward
Postby nemail » 2019-2-08 @ 11:23
it was pulled from my (still working) ISA386C...
nemail
Postby SteliosG » 2019-2-08 @ 12:01
My board was working till I removed the EPROM in order to read it with my programmer . It's sad , because I wanted to upload it and share it here in the forums , but in the process I managed to destroy a fully working BIOS . As a result , my EPROM doesn't boot .
Thank you jesolo for the link ! Unfortunately , I didn't know about the NSSI tools .
Till now , I only managed to find a different bios from a similar board (sis rabbit chipset) and I programmed it to an EEPROM . My board boots but it's stuck on slow mode (no cache activated) . The turbo jumper and the BIOS settings regarding the turbo & cache doesn't make any difference .
So , nemail … can you please try to extract the bios with the NSSI tool ? The "Final.txt" doesn't boot .
Thanks in advance . :)
SteliosG
Postby Anonymous Coward » 2019-2-11 @ 00:34
I've never heard of an EPROM being damaged simply by removing it, unless you phsyically break the chip or the glass window has been exposed to UV.
They're not particularly sensitive to static either. I've had EPROMs sit outside for years that are still readable. If it suddenly died, it must have been a defective chip.
User avatar
Anonymous Coward
Postby SteliosG » 2019-2-11 @ 13:37
When I removed the EPROM from my board , I peeled the sticker to check the code and make sure that the setting on my programmers are OK . It was a 27C512 . There is a second sticker underneath to protect the UV part which I didn't touch at all.
So , I read it on the programmer and saved the file . Just to be sure I tried a verify to compare the data on the chip with the data in the saved file . Strangely I started getting verify errors . There was a pattern and every XXXX bits there was an error .
I removed the EPROM and put it on my board and it was no longer booting .
My programmer was at the right mode because during these days I program a lot of 27E512 for my other old boards .
I still can't understand what went wrong as it's the first time in my long life that I destroy/corrupt an EPROM .
The most frustrating issue is that I can't find a bios that can enable the turbo mode (cache enabled) . The LED stays off whatever I tried (Jumpered switch and "enable" in bios) . So far a found 2 bioses that work only in slow mode .
So , Anonymous Coward … are you still looking for a BIOS ? I was going to extract the BIOS and upload it here for you and now I'm also looking for a working BIOS :(
SteliosG
Postby Predator99 » 2019-2-11 @ 16:51
I also had this behaviour with an EPROM: I repeated the reading many times without break. I watched the checksum displayed (in case you have a TL866). After the checksum displayed a constant value 2 or more times, I saved the image.
I repeated this procedure several times and compared the images I got with FC /B. There were not to many different bits in. The missing ones I got with watching excactly these bits in the TL866 windows during repeated readings...
You should also try to clean the contacts. In the TL866 you can play with the volatges, maybe also an option as last chance...
Predator99
Postby SteliosG » 2019-2-11 @ 19:13
I have an old LPT programmer . I tried reading it with a bit higher voltage (up to 6.3v from 5v) and I managed to read some more bits correctly , but no luck . The dump still has wrong bits …
SteliosG
Postby SteliosG » 2019-2-13 @ 01:11
Here's some good news ! :)
I have managed to repair my corrupted BIOS dump with the help of the dump that nemail had uploaded here . I'll explain the method tomorrow . It was an easy fix .
Everything works properly , turbo , cache … etc etc . It's 100000% correct ... and I'm happy !:)
I'll upload tomorrow the BIOS together with another one from another board I have .
SteliosG
Postby SteliosG » 2019-2-13 @ 21:08
Bios uploaded : viewtopic.php?f=46&t=60356&p=734769#p734769
I'm sure it will help some people ! :)
So , regarding the repair process here's what happened …
I noticed there was a pattern in the errors on my corrupted EPROM . Only bytes at addresses ending with 4 were bad and were giving verify errors . For example :
0000DED4
0000DF14
0000DF54
0000DF94
0000DFD4
0000E414
0000EF94
0000EFD4
0000F414
0000F454
0000F494
0000F4D4
0000F514
Overall there were something like 150 bad bytes .
So , I compared nemail's dump with my corrupted dump and noticed that the files were extremely similar !
I also knew that any difference at an address ending with "4" would be most probably cause of my bad EPROM .
Luckily , there were a few more bytes with differences (around 10 places) but they weren't in addresses ending with "4" ! That was a relief! :D
So all I've done was to change these 10 bytes in nemail's dump with the correct bytes from my dump .
Afterwards I programmed an W27C512 and board booted at full speed ! :)
SteliosG
Postby Anonymous Coward » 2019-2-14 @ 12:44
I will dig out my SiS rabbit board to try this latest dump, but I'm not optimistic.
*edit* Nope, it still doesn't work. The last 3 codes on my post card are 15, 20 then 00.
This is a weird board. The only 386 board I've tried that won't accept a different BIOS or post with a DLC installed.
User avatar
Anonymous Coward
Next
Return to General Old Hardware
Who is online
Users browsing this forum: darry, Kamerat, LHN91, NJRoadfan, sheath and 12 guests
