First post, by elod
I bought a 486 board with an AMD 5x86@133MHz CPU and some RAM that does not POST. It's an LS-486E rev.C2, SiS PCI chipset. http://motherboards.mbarron.net/models/486pci/ls486ec2.htm
When it arrived it had the CPU rotated by 90 degrees, I caught this right away.
VREG is set correctly (multimeter reads 3.4V), all other jumpers were set up right.
If I'm not mistaken it should beep even without a CPU and RAM, right?
What would you suggest I try besides battery replacement that did not help and maybe BIOS and cache reinsertion?
Does a 486 CPU/board survive a powerup with the CPU mounted wrong?
Reply 1 of 3, by Anonymous Coward
Depends on the board, and which way the CPU is oriented.
Reply 2 of 3, by Deksor
I rotated a DX2-80 at 180° by mistake. It died, but the mobo survived
Reply 3 of 3, by Mut
If everything is fine in the visual inspection, all votages are ok and jumpers are correct, check the bios, recently i revived a Atrend ATC1425 and a Soyo 4SAW2 only reflashing a new bios. I have a cheap willem programmer, but you can try this doing a hot swap or using a old nic and the uniflash utility.
