First post, by Vivien
Hi!
I'm trying to get a D-Link DFE-670TXD PCMCIA network card to work on my old HP Omnibook 425 laptop. The computer has Card and Socket Services version 1.08. But the drivers complain that I need v2.0 or 2.1.
I've never used PCMCIA on a DOS laptop so I'm kind of clueless as to what to do next. Google hasn't been helpful either. Any ideas?
Reply 1 of 21, by collector
Ask hardware questioons in Marvin. This forum is for DOS games on modern systems.
Reply 3 of 21, by lolo799
sorry, that card won't work, and you can't use a newer version of Card&Socket Services in the Omnibook.
You need to find a card that supports the HP palmtop series which use a similar pcmcia chipset and C&S Services as the Omnibook.
Such cards include the the Socket EA+, Accton 2216 and maybe the Netgear FA411.
Another way is to use a parallel ethernet adapter.
Reply 4 of 21, by Vivien
lolo799 wrote:
sorry, that card won't work, and you can't use a newer version of Card&Socket Services in the Omnibook. You need to find a card […]
Ah, too bad. I have none of those at home and although the Netgear is available on ebay it does lack a dongle. I can always rig a serial cable to a PC - but that solution is pretty cumbersome and I'd hoped to avoid it.
Reply 5 of 21, by Vivien
Out of curiosity, why won't it work? It's software, right? Why not simply install a newer version?
Reply 6 of 21, by Rawit
Attached are the OmniBook 600CT CardSoft and CardView folders. Not sure if these are useful. I rescued the folders from a defective drive, so something might be missing.
    cardstuff.zip
    274.68 KiB
    104 downloads
YouTube
Reply 7 of 21, by lolo799
The chipset they used either predates or doesn't conform to the standard, cards had to be designed on purpose for the OmniBook series.
You can run the utility tellme.com to see what chipset it detects:
Re: PCMCIA Sound Cards
Could you list the content of the Cardwoft folder from your 425?
You can always try Cardware 7 from http://www.tssc.de/, it supports a VLSI pcmcia chipset, but maybe not your model.
Reply 9 of 21, by Vivien
I couldn't find the folder. Where is it supposed to be?
The only relevant part I found was in CONFIG.SYS:
rem Install OBCIC, the Omnibook PCMCIA modem card recognizer TSR, with
rem generic modem recognition turned on.
rem Make sure OBCIC is installed after OBMGM...
install=d:\omnibook\obcic.exe /GEN 1
Tellme output:
C:\VOGONS\TELLME.COM
Tell Me The PCMCIA Host Adapter Version 2.25.1 (Mar 31 1997)
Copyright (C) OSITECH Communications, Inc. 1994-1997. All rights reserved.
Testing for PCI BIOS ... No PCI BIOS detected.
No recognized PCMCIA controller detected.
Trying to load the NIC driver as is:
C:\NIC\DFE-670\PKTDRV\dfe670pd.com
Packet Driver for D-Link DFE-670TXD Fast Ethernet PC Card, v1.00
Card Services is not found.
Registration for Socket Services has failed.
***I/O failure***
C:\NIC\DFE-670\DIAG\dfcd.exe
D-Link DFE-670TXD Fast Ethernet PC Card Client Driver v1.00
Socket Service response is error.
C:\NIC\DFE-670\DIAG\dfcd.exe /chk
[PC Card Environment]
Card Services : Not Installed
Socket Services : Installed
Adapter 0 : Unknown
[Socket Services Information]
Total # of Adapters : 1
# of Sockets in Adapter 0 : 4
SS Version : v1.00
[SS Implemented By]
HP CVD slf
Vendor's Version : v0.00
C:\NIC\DFE-670\DIAG\lsl.com
Novell Link Support Layer for DOS ODI v2.20 (960401)
(c) Copyright 1990 - 1996, by Novell, Inc. All rights reserved.
The configuration file used was "C:\NIC\DFE-670\DIAG\NET.CFG".
Max Boards 4, Max Stacks 4
C:\NIC\DFE-670\DIAG\dfe670.com
D-Link DFE-670TXD PC Card 16-bit MLID Driver v1.00 (2001-02-19)
Copyright(C) 2001 D-Link, All rights reserved.
Duplex mode: Full Duplex.
NWay disable.
IRQ 11, Port 300, Mode Address B8B8B8B8B8B8 L
Max Frame 1514 bytes, Line Speed 100 Mbps
Board 1, Frame ETHERNET_802.3, LSB Mode
Adapter RAM error.
DFE670-DOS-6: The adapter did not initialize. DFE670 did not load.
Attempting to use the OB600CT Cardsoft:
SystemSoft Socket Services 2.1 OmniBook Version 2.02
Copyright 1993 SystemSoft Corporation. All Rights Reserved.
Copyright 1993, 1994, 1995 Hewlett-Packard Company All Rights Reserved.
OmniBook PCMCIA adapter not found
SystemSoft OmniBook Socket Services not installed
SystemSoft Card Services 2.1 Version 2.06 (2256-12)
Copyright 1993-1994 SystemSoft Corporation. All Rights Reserved.
*** Installation Failed: Socket Services Is Not Release 2.10
The system then halts execution and even CTRL-ALT-DEL does not work. I had to press the reset button and remove the relevant parts from CONFIG.SYS.
Attempting to install Cardware 7: the setup program asks for a platform but the OB425 isn't listed and I couldn't find the "Controller Autodetect" option that the setup program recommended. Is my controller PCIC or TCIC? I tried to proceed anyway but when asked to select PCIC/TCIC/TACT Socket Services I didn't know what to pick. So I let the default be and pushed on.
DPMS 1.44 Copyright (c) 1992, 1994 Novell, Inc. All rights reserved.
Card Services/386 Level 5.02 - Version 7.00 - Release 27-Sep-2007
(C) Copyright 1992-2007 by APSoft.
All rights reserved. Disassembly or decompilation prohibited.
Please, specify serial number or press ENTER without any input for run
evaluation version
CD0700-009-EN-049-001-
You are running an evaluation copy of CardWare. This version expires in 14 days.
Please refer to the file README.TXT in CardWare installation directory for
information how to license CardWare.
Please wait 1 seconds
Detect APM BIOS Version 1.01 installed and enabled.
Detect POWER.EXE Version 1.00 installed and enabled.
Detect DPMS Server Version 1.00 (Novell Version 1.44) installed
Socket Services not loaded
Card Services installed successfully.
Loading to extended memory via DPMS interface
Socket Services Level 7.00 - Version 7.00 - Release 27-Sep-2007
Detect Card Services Level 5.02 (Executed in Protected mode)
SS docking support is disabled!
ERROR: No PC Card adapter detected!
Socket Services installation aborted
PCENABLE/386 Version 7.00 - Release 27-Sep-2007
WARNING: Socket Services not loaded
PCENABLE installed successfully.
PCATA/386 Version 7.00 - Release 27-Sep-2007
PCATA installed successfully.
PCSRAM/386 Version 7.00 - Release 27-Sep-2007
Show last 27 lines
PCSRAM installed successfully.
PCFLASH/386 Version 7.00 - Release 27-Sep-2007
PCFLASH installed successfully.
PCDISK/386 Version 7.00 - Release 27-Sep-2007
ERROR: Socket Services not loaded
PCDISK Installation aborted
Perhaps I need to choose different settings?
Huh. On a whim I tried running dfe670pd.com and it actually appears to have loaded. This despite all the errors above. Did Cardware 7 actually do something helpful?
Ethernet PC Card Card Enabler installation has completed.
Packet interrupt number 0x62 (98)
I/O address 0x300 (768)
Interrupt number 0xB (11)
Memory address 0xD000 (53248)
PCMCIA slot 0x0 (0)
NWay processing ... Auto-Negotiation completely.
Line Speed: 10 Mbps.
Duplex mode: Half Duplex.
NWay enable.
I/O Base = 0x0300, IRQ = 11, Slot = 0
Card Services : Installed
Socket Services : Protected by CS
Adapter 0 : Unknown
CS Version : v5.02
[CS Implemented By]
Former Award and TouchStone product
Vendor's Version : v7.00
# of Sockets Managed by CS : 0
I'll have to test this some more. Could be just a fluke.
Reply 10 of 21, by Rawit
I checked the Omnibook archive http://omnibooks.info/archive/, but I didn't see anything Omnibook 425 PCMCIA related there.
That doesn't look hopeful. You would expect something more universal, not modem card specific. Looks like lolo799 is right about the early Omnibooks.
YouTube
Reply 11 of 21, by Vivien
Well... even though the driver loads without complaint, I can't get out onto the network.
C:\WIN311\ping 127.0.0.1
Pinging [127.0.0.1] with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time=500ms TTL=32
Reply from 127.0.0.1: bytes=32 time<10ms TTL=32
C:\WIN311\ping 192.168.0.1
Pinging [192.168.0.1] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
I even installed dos 6.22 and windows 3.11 in a virtual machine simply to make sure I was doing things properly. It worked there, but not in the Omnibook. 🙁
Reply 12 of 21, by Vivien
So the adapter defaults to 0x0300 and IRQ = 11. Is there perhaps a conflict? I am uncertain.
       Microsoft Diagnostics version 2.11    3/10/16    1:14pm   Page  1
------------------------ Summary Information --------------------------
Computer: Phoenix/Phoenix, 486SX
Memory: 622K, 7168K Ext, 4783K XMS
Video: XGA, Unknown
Network:
OS Version: MS-DOS 5.00
Mouse: Bus Mouse
Other Adapters: Game Adapter
Disk Drives: A: B: C: D:
LPT Ports: 2
COM Ports: 3
Windows Information: 3.11, Not Active
------------------------------ Computer -------------------------------
Computer Name: Phoenix
BIOS Manufacturer: Phoenix
BIOS Version:
BIOS Category: IBM PC/AT
BIOS ID Bytes: FC 01 00
BIOS Date: 07/31/93
Processor: 486SX
Math Coprocessor: None
Keyboard: Enhanced
Bus Type: ISA/AT/Classic Bus
DMA Controller: Yes
Cascaded IRQ2: Yes
BIOS Data Segment: 9B80 18k
Microsoft Diagnostics version 2.11 3/10/16 1:14pm Page 2
------------------------------- Memory --------------------------------
Legend: Available " " RAM "##" ROM "RR" Possibly Available ".."
EMS Page Frame "PP" Used UMBs "UU" Free UMBs "FF"
1024K FC00 RRRRRRRRRRRRRRRR FFFF Conventional Memory
F800 RRRRRRRRRRRRRRRR FBFF Total: 622K
F400 RRRRRRRRRRRRRRRR F7FF Available: 460K
960K F000 RRRRRRRRRRRRRRRR F3FF 471360 bytes
EC00 RRRRRRRRRRRRRRRR EFFF
E800 RRRRRRRRRRRRRRRR EBFF Extended Memory
E400 RRRRRRRRRRRRRRRR E7FF Total: 7168K
896K E000 RRRRRRRRRRRRRRRR E3FF
DC00 ........FFFFFFFF DFFF MS-DOS Upper Memory Blocks
D800 ........FFFFFFFF DBFF Total UMBs: 114K
D400 ........FFFFFFFF D7FF Total Free UMBs: 70K
832K D000 ................ D3FF Largest Free Block: 25K
CC00 FFFFFFFFFFFFFFFF CFFF
C800 UUUUUUFFFFFFFFFF CBFF XMS Information
C400 UUUUUUUUUUUUUUUU C7FF XMS Version: 3.00
768K C000 UUUUUUUUUUUUUUUU C3FF Driver Version: 3.10
BC00 ################ BFFF A20 Address Line: Enabled
B800 ################ BBFF High Memory Area: In use
B400 FFFFFFFFFFFFFFFF B7FF Available: 4783K
Show last 258 lines
      704K B000 #####UUUUUUFFFFF B3FF    Largest Free Block: 4783K
AC00 ################ AFFF Available SXMS: 4783K
A800 ################ ABFF Largest Free SXMS: 4783K
A400 ################ A7FF
640K A000 ################ A3FF
------------------------------- Video ---------------------------------
Video Adapter Type: XGA
Manufacturer: Unknown
Model:
Display Type: VGA Color
Video Mode: 3
Number of Columns: 80
Number of Rows: 25
Video BIOS Version: Version 1.4.0
Version 1.4.0
Video BIOS Date:
VESA Support Installed: No
Secondary Adapter: VGA
Microsoft Diagnostics version 2.11 3/10/16 1:14pm Page 3
----------------------------- OS Version ------------------------------
Operating System: MS-DOS 5.00
Internal Revision: 00
OEM Serial Number: FFH
User Serial Number: 000000H
OEM Version String: Hewlett-Packard MS-DOS 5.00 - E.0
0.00
DOS Located in: ROMHMA
Boot Drive: C:
Path to Program: C:\NIC\MSD.EXE
Environment Strings
COMSPEC=D:\COMMAND.COM
PATH=C:\WIN311;C:\;C:\WINDOWS;C:\WINWORD;C:\EXCEL;C:\DOS;C:\MOUSE;C:\MSM
IL;D:\TSI;D:\
PROMPT=$p$g
TEMP=c:\windows\temp
TMP=c:\windows\temp
MOUSE=c:\mouse
------------------------------- Mouse ---------------------------------
Mouse Hardware: Bus Mouse
Driver Manufacturer: No Mouse Driver
--------------------------- Other Adapters ----------------------------
Game Adapter: Detected
Joystick A - X: 0
Y: 0
Button 1: On
Button 2: On
Joystick B - X: 2
Y: 1
Button 1: Off
Button 2: On
Microsoft Diagnostics version 2.11 3/10/16 1:14pm Page 4
---------------------------- Disk Drives ------------------------------
Drive Type Free Space Total Size
A: Floppy Drive, 5.25" 360K
265 Cylinders, 64 Heads
B: Floppy Drive, 5.25" 1.2M
C: Fixed Disk, CMOS Type 255 440M 487M
992 Cylinders, 16 Heads
512 Bytes/Sector, 63 Sectors/Track
D: Remote Drive 8162K 8192K
512 Bytes/Sector
SHARE Installed
LASTDRIVE=Z:
----------------------------- LPT Ports -------------------------------
Port On Paper I/O Time
Port Address Line Out Error Out Busy ACK
LPT1: 0378H Yes Yes No No Yes No
LPT2: 0278H No Yes No No No No
LPT3: - - - - - - -
----------------------------- COM Ports -------------------------------
COM1: COM2: COM3: COM4:
Port Address 03F8H N/A 03E8H N/A
Baud Rate 2400 2400
Parity None None
Data Bits 8 8
Stop Bits 1 1
Carrier Detect (CD) No No
Ring Indicator (RI) No No
Data Set Ready (DSR) No Yes
Clear To Send (CTS) No Yes
UART Chip Used 16550AF 16550AF
Microsoft Diagnostics version 2.11 3/10/16 1:14pm Page 5
------------------------ Windows Information --------------------------
Windows version: 3.11
Windows mode: Not Active
Windows Directory: C:\WIN311
System Directory: C:\WIN311\SYSTEM
Filename Size Date Time
VNETSUP.386 14647 4/25/09 21:14
VREDIR.386 85746 4/25/09 21:14
VSERVER.386 101054 4/25/09 21:14
VTDAPI.386 5245 4/25/09 21:14
VPMTD.386 5653 4/25/09 21:14
VCOMM.386 5688 4/25/09 21:14
SERIAL.386 11112 4/25/09 21:14
LPT.386 5917 4/25/09 21:14
IFSMGR.386 65625 4/25/09 21:14
VCACHE.386 9862 4/25/09 21:14
VSHARE.386 14925 4/25/09 21:14
RMM.D32 11894 4/25/09 21:14
----------------------------- IRQ Status ------------------------------
IRQ Address Description Detected Handled By
0 C105:1875 Timer Click Yes Block Device
1 C80D:069C Keyboard Yes KEYB
2 F000:DB71 Second 8259A Yes BIOS
3 F000:DB71 COM2: COM4: No BIOS
4 F000:DB71 COM1: COM3: COM1: COM3: BIOS
5 F000:DB71 LPT2: Yes BIOS
6 217D:00B7 Floppy Disk Yes Default Handlers
7 0070:078F LPT1: Yes System Area
8 217D:0052 Real-Time Clock Yes Default Handlers
9 F000:D92C Redirected IRQ2 Yes BIOS
10 F000:DB71 (Reserved) BIOS
11 F000:DB71 (Reserved) BIOS
12 F000:DB71 (Reserved) BIOS
13 F000:D91D Math Coprocessor No BIOS
14 217D:0117 Fixed Disk Yes Default Handlers
15 F000:DB71 (Reserved) BIOS
Microsoft Diagnostics version 2.11 3/10/16 1:14pm Page 6
---------------------------- TSR Programs -----------------------------
Program Name Address Size Command Line Parameters
??? 030F 115760
System Data 1F53 12640
HIMEM 1F55 1104 XMSXXXX0
EMM386 1F9B 3088 EMMQXXX0
File Handles 205D 1488
FCBS 20BB 256
BUFFERS 20CC 512
Directories 20ED 2288
Default Handlers 217D 3792
System Code 226A 64
Free Memory 226F 48
OBMGM.COM 2273 32 OBM
OBMGM.COM 2276 20656 OBM
COMMAND.COM 2782 2368 /b /i
Free Memory 2817 64
COMMAND.COM 281C 1024 /b /i
NET 285D 208 /b /i
MSD.EXE 286B 335040 /b /i
MSD.EXE 7A38 10032 /b /i
MSD.EXE 7CAC 24576 /b /i
Free Memory 82AD 101648
Excluded UMB Area 9B7F 89280
Free Memory B14C 208
SHARE.EXE B15A 6192
Free Memory B2DE 20976
Excluded UMB Area B7FE 32800
System Data C001 3872
IFSHLP C003 3856 IFS$HLP$
SMARTDRV C0F4 29040
KEYB C80C 6208 ei,850,d:\keyboard.sys
Free Memory C991 26304
Excluded UMB Area CFFE 24608
Free Memory D601 8128
Excluded UMB Area D7FE 8224
Free Memory DA01 8128
Excluded UMB Area DBFE 8224
Free Memory DE01 8160
Microsoft Diagnostics version 2.11 3/10/16 1:14pm Page 7
--------------------------- Device Drivers ----------------------------
Device Filename Units Header Attributes
NUL 01D0:0048 1............1..
Block Device 1 C105:21B2 .1..1....1....1.
Block Device 4 C105:21C4 .11.1...11....1.
IFS$HLP$ IFSHLP C003:0000 11.1............
$MMXXXX0 1F9B:003A 11..............
EMMQXXX0 EMM386 1F9B:0000 11..............
XMSXXXX0 HIMEM 1F55:0000 1.1.............
Block Device DBLSPACE 1 1789:0000 .1..1....1....1.
FFS20$ MS-FLASH 0632:0000 1...............
MRCI100$ MRCI 0311:0000 1...............
CON 0070:0029 1..........1..11
AUX 0070:003B 1...............
PRN 0070:004D 1.1.....11......
CLOCK$ 0070:005F 1...........1...
Block Device 4 0070:0071 .11.1...11....1.
COM1 0070:0081 1...............
LPT1 0070:0093 1.1.....11......
LPT2 0070:00B8 1.1.....11......
LPT3 0070:00CA 1.1.....11......
COM2 0070:00DC 1...............
COM3 0070:00EE 1...............
COM4 0070:0100 1...............
POWER$ 0070:0112 1...............
---------------- ROM BIOS F000 65536 ------------------
F000:E020 Copyright (c) 1985,1986,1987 Phoenix Technologies Ltd
F000:6680 EMMXXXX0MICROSOFT EXPANDED MEMORY MANAGER 386COMPAQ EXPANDED M
EMORY MANAGER 386`
F000:2F46 MS-BIOS
F000:7FD0 OBCBIOS
F000:7FF0 BIOS0
F000:E158 All Rights Reserved
---------------- Option ROM E800 50176 ------------------
E800:02BC MS DOS Version 5.00 (C)Copyright 1981-1991 Microsoft Corp Lice
nsed Material - Property of Microsoft All rights reserved <
E800:AF46 MS-BIOS
---------------- Option ROM E000 32768 ------------------
E000:008B Chips 65510 VGA BIOS.
Version 1.4.0
DECOMPILATION OR DISASSEMBLY PROHIBITED
E000:012B Copyright (C) 1992 Chips and Technologies, Inc. All Rights Re
served.
E000:0004 ?7400000000000000000000000IBM VGA Compatible BIOS. 5
I don't know why MSD got the date and time wrong. I checked the settings and they are correct. I also sent off an e-mail to "support@tscc.de", perhaps they can offer some insight.
Reply 14 of 21, by Vivien
Ok, but I'm warning you! It's a mess! 😉
rem
rem CONFIG.SYS -- OmniBook default startup file for drive C (also
rem uses drive D).
rem
rem This version enables all OmniBook capabilities. It requires
rem Flash File System for drive D, and is compatible with DoubleSpace
rem for drive C.
rem SHELL must refer to COMMAND.COM on drive D...
shell=d:\command.com /p /e:1024 d:\
rem Install HIMEM.SYS, the extended memory manager...
device=C:\WIN311\HIMEM.SYS /machine:2 /testmem:off
device = c:\win311\emm386.exe noems i=b000-b7ff X=D000-DFFF
dos=high,umb
rem OBMGM must be installed for the system to boot...
install=d:\omnibook\obmgm.com
rem install c:\nic\ob600\omnibook\obmgm.com
rem Install country settings for United Kingdom. NOTE: This version
rem of the OmniBook has hardware code page 850 instead of 437.
country=044,850,d:\country.sys
rem Install the DISPLAY.SYS driver if you wish to change code pages.
rem device=d:\display.sys con=(ega,850,1)
rem Install OBCIC, the OmniBook PCMCIA modem card recognizer TSR, with
rem install=d:\omnibook\obcic.exe /GEN 1
rem To install the Pacific Rim Systems parallel line floppy disk driver
rem (3.5-inch 1.44-MB drive), remove the "rem" from the next device= line...
rem device=d:\omnibook\prspf.sys
rem Set other system variables.
rem If SMARTDrive is installed, BUFFERS can be set to 10...
files=30
buffers=30
rem OmniBook needs at least 12 stacks available...
stacks=12,256
rem LASTDRIVE=Y leaves one drive letter available for Novell networks...
lastdrive=Z
DEVICEHIGH=C:\WIN311\IFSHLP.SYS
rem device=c:\vogons\card\cardsoft\obss.exe
rem device=c:\vogons\card\cardsoft\cs.exe
Show last 13 lines
rem device=c:\vogons\card\cardsoft\cs_apm.exe
rem device=c:\vogons\card\cardsoft\csalloc.exe
rem device=c:\vogons\card\cardsoft\cardid.exe
DEVICE = C:\CARDWARE\DPMS.EXE MEM=XMS
DEVICEHIGH = C:\CARDWARE\PCCS.EXE /SC:off /MC:15
DEVICEHIGH = C:\CARDWARE\SSPCIC.EXE /AP:on /VS:auto /EC:auto /II:off /MX:off
DEVICEHIGH = C:\CARDWARE\PCENABLE.EXE
DEVICEHIGH = C:\CARDWARE\PCATA.EXE
DEVICEHIGH = C:\CARDWARE\PCSRAM.EXE
DEVICEHIGH = C:\CARDWARE\PCFLASH.EXE
DEVICEHIGH = C:\CARDWARE\PCDISK.EXE
@echo off
rem
rem AUTOEXEC.BAT -- OmniBook default startup file for drive C
rem (also uses drive D).
rem
LH C:\WIN311\net start
rem LH C:\WIN311\SMARTDRV.EXE
rem Install alternate code page. The English (International) OmniBook
rem has code page 850 as the hardware code page. NOTE: You must add
rem device=display.sys line to config.sys.
rem d:\mode con cp prep=((437)d:\ega.cpi)
rem d:\mode con cp select=437
rem Install keyboard driver for English (International)
rem LH d:\keyb ei,850,d:\keyboard.sys
rem To install SMARTDrive for a hard disk, remove the "rem" from the
rem smartdrv command line. The command line specifies no read or write
rem caching for drive A or B, and only read caching for drive C.
rem d:\windows\smartdrv.exe a- b- e
rem The PATH must include D:\ at the end to allow access to MS-DOS
rem programs and Windows programs and help files.
path=C:\WIN311;c:\;c:\windows;c:\winword;c:\excel;c:\dos;c:\mouse;c:\msmail;d:\tsi;d:\
rem Set other environment variables.
prompt $p$g
set temp=c:\windows\temp
set tmp=c:\windows\temp
set mouse=c:\mouse
rem Check for a drive C that is not initialized to run Windows.
rem d:\obsetup
rem Install SHARE (required by Microsoft Mail).
LH d:\share
rem To install the MS-DOS mouse driver, remove the "rem" from the
rem obmouse command line.
d:\obmouse
rem Change to drive C in case OmniBook booted from drive D.
c:
rem Run Windows using the WIN.BAT batch file.
rem call d:\win
REM Inserted by CARDWARE Setup *** Start
Show last 3 lines
PATH C:\CARDWARE;%PATH%
REM Inserted by CARDWARE Setup *** End
Reply 15 of 21, by Vivien
I attempted to check if the NIC works on another computer but found out that my 2008 ASUS has an incompatible ExpressCard slot. So I went down to the basement and started digging. Aside from a remarkable number of ISA cards and old SIMM memory, I found my old P2 laptop with the busted screen that I used as a server for a while. Unfortunately when connected to power the external VGA output does not display any video nor can I hear any POST beep. 🙁
Reply 16 of 21, by lolo799
You can remove the following lines from your config.sys:
Try the other Socket drivers from cardware, sstact.exe and sstcit.exe instead of sspcic.exe.
You can also try those versions of ssvlsi.exe, instead of obss.exe:
http://www.elhvb.com/mobokive/Archive/AAeon/d … soft/index.html
http://penwin.stg.net/files/compaq%20concerto/Win3/PCMCIA.1/
Reply 17 of 21, by Vivien
No joy for sspcic, sstcic, or sstact.
ssvlsi no. 1 outputed:
SystemSoft Socket Services 2.1 VL82C146 Version 1.01 (2173-06)
Copyright 1993-1994 SystemSoft Corporation. All rights Reserved
VL82C146 PCMCIA adapter not found
SystemSoft VL82C146 Socket Services not installed
ssvlsi no. 2 outputted:
SystemSoft Socket Services 2.1 VL82C146 Version 1.01 (2243-08)
There was only a slight difference in the numbers after the version number. I also tried every ss* in both folders. sscirrus and ssvadem run without complaint, but regrettably do not appear to work. Non-standard hardware really is a pain. Thank you for trying though.
Reply 19 of 21, by Vivien
Found an interesting link: http://www.vcfed.org/forum/archive/index.php/t-38300.html
It didn't work, but the LXCIC output:
C:\NIC\LXCIC\LXCIC.COM
LXCIC V2.1 (c) 99 Stefan Peichl, Heidelberg
ADR=0300 COR=41 FCSR=20 BASE=0200 ID=06
SocketService I/O enabled
Interesting that it recognized it...
