First post, by Elia1995
- Oldbie
Hello guys !!! So long I haven't connected here, but currently I don't have a working connection at home.
PROBABLY this is the wrong forum section, eventually feel free to move this thread.
Anyway, I'm doing further experiments with my famous Celeron build after Win98 died by itself (no wonder I want to make that PC a DOS machine, mainly) and, since I can't find my original MS-DOS 6.22 floppies, I decided to give FreeDOS a try for once.
The installation from CD went smooth and slow (as supposed to be, with such specs...). When I try to boot it up after installation, it won't boot up, it gets stuck at "Booting from local disk..." if I leave the CD in and press "Boot from system harddisk", or at "Searching for Boot Record from IDE-0..OK"
I dunno what to do, I even installed it twice and yet it does that thing... it doesn't even run from the boot floppy I created within the CD installation menu "Make a boot floppy", it just says "Disco non di avvio. Sostituire il disco e premere un tasto." (Non boot disk, substitute the disk and press a key)
I'd install Dr. DOS again in there, if only I didn't lose the last 2 floppies.... but I really wanted to give FreeDOS a try...
as much as I understood, it seems a problem with the boot loader not booting up, something like MBR, but how can I restore it ? I even installed the system twice and didn't fix by itself...
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
