Reply 20 of 43, by Elia1995
I just installed Win 3.11 over Win 3.11 and nothing at all changed.
The cursor is still there, stuck in the middle not moving by a single pixel whatever I do with the mouse.
Now the famous C:\WINDOWS\SETUP.EXE works as it should, showing me the correct thing with the options, from which I tried every single one of the available mice selection, but NONE of them works, all doing the same thing except Logitech.
With "Logitech" the cursor disappears completely.
I also tried "Other", put in the directory where I copied my CTMouse, but it can't find some "OEMFILE.INF" file, I also tried from the floppy, but this file is nowhere to be found...
It's strange, this NEVER happened to me before, I always used Win3.11 with this exact mouse and I never had this problem at all... and the strangest fact is that it's happening on MS-DOS 6.22 !!!
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 21 of 43, by Jo22
Okay and what does ctmouse say when it loads the first time ?
Knowing this could perhaps help us to understand how your mouse is handled by the computer.
Reply 22 of 43, by Elia1995
Ok, it says this:
CuteMouse v2.0 alpha 4 [FreeDOS]
Installed at PS/2 port (wheel present)
MSCDEX Version 2.23
Copyright (c) Microsoft Corp. 1986-1993. Tutti i diritti riservati.
if I launch it a second time, it says this:
Resident part reset to PS/2 port (wheel present)
Reply 23 of 43, by yawetaG
MSCDEX is the DOS CD-ROM driver. Apparently it gets loaded just after your mouse driver, so the message shows up just after the message about the mouse driver loading.
What happens if you remove the DOS mouse driver completely, reboot, and then try to install the Windows mouse driver?
Reply 24 of 43, by Elia1995
You mean leaving there only Windows 3.11's "MOUSE.DRV" ?
But that way shouldn't I have problems getting the mouse to work in DOS ???
Reply 25 of 43, by yawetaG
Yes. The objective is to check whether there is some kind of incompatibility between the two drivers. If the mouse works that way in Windows, you'll need to find another DOS mouse driver that doesn't have this problem.
Although it might be that it's just a problem when combining FreeDOS and Windows 3.11.
Reply 26 of 43, by Elia1995
but I'm on MS-DOS 6.22 !!!
Anyway, let's try out this experiment 😁
It still doesn't move...
Reply 27 of 43, by yawetaG
Oh, got things mixed up with your other thread. 😊
Weird. What make is your mouse?
Reply 28 of 43, by Elia1995
It's an optical PS/2 "Manhattan" mouse with a scrolling wheel. Model: 176972
I NEVER had issues with this mouse with Windows 3.11/DOS, it ALWAYS worked just fine on my 386, 486, on this very PC except this time.....
Reply 29 of 43, by yawetaG
Okay, that should exclude the mouse itself, especially since you wrote the same happens with a serial mouse. Did you change anything on the computer itself besides the software? An IRQ conflict is explicitly mentioned as a cause for a mouse failing to work in Windows in my manual.
I must say I've only used Microsoft- or Logitech-compatible mouses in Windows 3.11, together with the appropriate OEM drivers...
Reply 30 of 43, by Elia1995
So... any idea ?
Reply 31 of 43, by Jo22
PS/2 uses IRQ12 - is it beeing used by something else (network card, etc.) ?
Reply 32 of 43, by Elia1995
hmmm.... nope, no sign of IRQ 12 usage in the boot screen where it lists all the IRQs and ISA PnP devices.
Reply 33 of 43, by Jo22
Hmm.. Your PC is really strange, but interesting! 😀
My last idea so far: If you have got some spare time, try to install Win9x and check the device manager.
Especially for yellow marks. If you can, write down (or copy&paste or print) the important/strange devices your PC has installed.
Maybe this helps you to find out about their oddities on the web.. Or if you PC has Plug&Pray already, run NSSI or Speedsys.
These are also able to list ISA PnP/PCI devices..
Reply 34 of 43, by Elia1995
NSSI ?
Reply 35 of 43, by Jo22
Elia1995 wrote:
NSSI ?
Navrátil Software System Information.
http://www.navsoft.cz/products.htm
Reply 36 of 43, by Elia1995
Ah that one... yeah...
anyway I got the mouse finally working... with another mouse driver. Screw CTMouse !!!
I looked for another DOS mouse driver and I found one at a site called "bootdisk.com" or something like that, it's made of a single file "mouse.com", I put it in my C:\ and in C:\WINDOWS and I edited the autoexec so it would "LH C:\MOUSE.COM" at boot.
I then changed the mouse in Windows 3.11 again into "Microsoft or IBM PS/2", rebooted Windows 3.11 and BINGO the cursor FINALLY moves again in Windows 3.11 !!! And it works in DOS aswell.
Well... apparently this CTMouse driver is full of crap, loads of files for a buggy driver which gets stuck in Windows 3.11... this one instead is made of just ONE file (mouse.com) and works in both DOS and Windows 3.11 !! 😁
Reply 37 of 43, by yawetaG
Elia1995 wrote:
Ah that one... yeah... […]
So it was the DOS driver. Great it all worked out! FYI, according to my Windows manual, MOUSE.COM or the alternative MOUSE.SYS might be included on the Windows floppies. This driver should also support use of the mouse in windowed DOS programs running under Windows.
Reply 38 of 43, by Elia1995
Then it's weird that I didn't find it in my C:\WINDOWS directory (when I copied this mouse.com driver from the floppy, it didn't ask me to replace anything)
Reply 39 of 43, by Jorpho
I vaguely recall older versions of CuteMouse being recommended in some situations.
