First post, by fsmith2003
I recently came across a Tandy 1000 TL/2 for cheap. Th only thing is that the HDD does not work. I had to replace the floppy drive with a more modern 1.44 using the "hole punch" method on the ribbon cable. So I have a working machine with one working floppy drive but no HDD. It is for that reason I am looking for the disk structure of the original IBM compatible Pirates! game. I have all the files on an old computer but no longer have any disk. SO if i could get the file structure from someone who does then maybe I can throw something together to play off of the floppy drive? Thanks in advance!
