First post, by jheronimus
Hi, all!
I want to build a 486 pure DOS machine with AMD 5x86 and Cirrus Logic CL-5428. I have an AWE32 CT3990 card for it as well as SB32 CT3670 and AWE64 CT4500.
I always thought that AWE32 sounded like this in General MIDI and if you wanted to get something out of it, you needed to load .sbk soundbanks, and that means using Windows. Loading takes a lot of time and you have to do it after each reboot.
However, yesterday, I've stumbled upon this recording and I am a bit confused now:
- E-mu is the name of the synthesizer chip on the card. Or is the author referring to an 8MB soundbank that he loaded before taking a recording? Why is the output so much better?
- if I add 32 MB of RAM to AWE32 (or any RAM), I'll need to disable the card's internal 512KB ROM via jumpers. Does that mean that the default soundbank will be loaded into the external RAM on each reboot? Will it be the same soundbank?
- how will I benefit from expanded RAM under DOS?
So, in a nutshell I'm trying to understand if AWE32 automatically gets a better sound output with extra RAM and if 32MB can be useful if I don't want to bother with custom soundbanks or Windows.
MR BIOS catalog
Unicore catalog
Reply 1 of 8, by brostenen
Actually never tried soundbanks out my self. I find the standard "settings" good enough.
On the other hand. I have thought about trying it from time to time.
Reply 2 of 8, by jheronimus
Do you use extra memory? Does Doom sound more like the first video for you or the second?
MR BIOS catalog
Unicore catalog
Reply 3 of 8, by bristlehog
Yes, he's referring to a 8 Mb E-MU sound bank he loaded.
The default sound bank is located in ROM. It is thus never loaded to any RAM.
You probably won't. Very few games can take advantage of AWE32's RAM in DOS. Some of them only need 512 Kb of internal RAM. You can find more info here.
However, in DOS you can load SF2 banks and play MIDI files with AWEPLAY by Günther Klaming or XMI files with SFXPLAY by me. Also, you can play MOD and XM files with AWEPLAY by Thor (this is different from AWEPLAY by Guenther Klaming) - here AWE32's memory is used to load MOD/XM embedded samples into it.
In a nutshell it doesn't and 32 Mb aren't useful.
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 5 of 8, by chinny22
This is why I think the AWE32 Value cards are a good deal and can still be found for good prices on ebay (well for ebay)
Reply 6 of 8, by Jorpho
Wasn't there a way to load a different, larger soundfont bank in DOS by substituting it for one of the default banks? Like, replacing synthmt.sbk and then loading AWEUTIL with the /EM:MT32 switch?
Reply 7 of 8, by brostenen
I have the CT3900, though I do not use mem upgrade, I keep holding on to it because of the OPL chip on it.
Reply 8 of 8, by jesolo
Yes, provided you can find GM (or MT-32) compatible soundfonts in the version 1 format (*.sbk), then you can replace the synthgm.sbk (the one used for GM compatibility mode) or the synthmt.sbk (the one used for MT-32 compatibility mode) files by renaming your soundfont to match the names as mentioned above.
When you then load Aweutil with the /EM:GM (or /EM:MT32) parameter, it will then load that soundfont.
Just ensure that you rename and place your files in the SFBANK sub directory under your main Sound Blaster folder (normally C:\SB16\SFBANK).
However, this is only useful for games that are not running in protected mode (i.e., does not use a DOS extender like DOS/4GW).
Aweutil does not support protected mode games and those games must natively support the AWE32 (i.e., in the game's setup menu, you must choose AWE32 for MIDI playback). This means that, in most cases, protected mode games will simply use the standard 1MB GM ROM sample set that is found on the AWE32.
You can, however, play most protected mode games from a command prompt (from within Windows 95 or 98) and then load any soundfont you want under Windows (can be either a version 1 or version 2 soundfont).
In doing so, you can expand your options (since there are quite a number of good soundfont version 2 formats out there, which uses the extension *.sf2).
In such a case, you would then select General MIDI (not AWE32) in the game's setup menu.
