Finished, Finally!
Reply 20 of 22, by rick12373
MCGA wrote:
Maybe this thread will help:
Issues with an AWE32?
There's a newer(other) mixerset you can download that might fix your problem.
If I try using that I get "MIX0002: Incorrect AUXDRV.DRV driver version".
I wish I could figure this last problem out, I just want to be able to increase the volume of the Sound Blaster.
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 21 of 22, by rick12373
Figured it out! I had the following in my CONFIG.SYS:
REM THE FOLLOWING 2 LINES ARE NOT NEEDED BY 99% OF GAMES
REM DEVICE=C:\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5
REM DEVICE=C:\SB16\DRV\CTMMSYS.SYS
I must have read somewhere that I should keep them REM'd out unless it was one of the few games that needed it. I think I should just keep them loaded anyway, the volume is much better in all of the games I have tested it in and SB16SET now works.
SB 16 Value CT2770
