Athlon xp gpu upgrade didn't go well
First post, by APFSDS
Hi it's my first time on the form. I have a problem with my AIW x800xt it go's blank any time a game shows 3d objects. I,m not sure if it's the nforce motherboard.
Specs
Cpu Athlon xp 3000+ fsb 200
Motherboard MSI k7n2
Ram 1gb ddr cl2 supertalent
Psu 350 inwin
Sound. Sound blaster x fi
Chipset nforce2
Is xp pro
Gpu current aiw x800xt previous leadtek fx 5900
Reply 2 of 22, by Nipedley
I use an X800 Pro with an nForce 2 motherboard and Athlon XP 3200 no trouble at all, I would agree with the previous poster PSU or drivers. I remember especially back in the old days ATI and Nvidia drivers did not agree, I would usually reinstall if I decided to swap sides !
Reply 3 of 22, by Tetrium
APFSDS wrote:
Psu 350 inwin
kanecvr wrote:
Sounds like a PSU or driver issue.
^agreed
My retro rigs (old topic)
Report spammers here!
Reply 4 of 22, by Ampera
Sounds like it could also be a possible reflow issue, but definitely try it in another system with the right drivers and a known-good PSU first, then if you can't do anything else, set about reflowing, maybe your local maker-space will be kind enough to help you for a fiver.
Reply 8 of 22, by Tetrium
APFSDS wrote:
I didn't see a bridge chip when i tuck the cooler off.
Iirc sometimes the bridge chip was on the backside of the PCB?
And if you want, if you want you could upload a few pics of your card so we can have a look at it 😀
Also the psu didn't go well.
It died? It exploded? It electrocuted your cat?
Reply 9 of 22, by candle_86
an AGP X800 had both Native AGP and PCIexpress verions of the major R42xx chipsets because ATI didn't trust bridge chips, if its an R420 its for sure AGP native
Reply 10 of 22, by kanecvr
Try doing a clean windows install if you swapped out the PSU, although 90% of the time the kind of instability you described is PSU related.
Reply 12 of 22, by Ampera
PSU blowing a cap = never use PSUs from that brand until 10 years after the release of that PSU if no further issues have been reported.
I am currently sitting on a slightly off name PSU with decent performance, but pretty poor reliability ratings. It's lasted for years, so I am going to leave it for now.
Reply 13 of 22, by gdjacobs
Not necessarily a good rule. Good designs sometimes used bad caps (I'm looking at you Antec!).
Reply 16 of 22, by Tetrium
APFSDS wrote:
Pic of card
I hope you didn't put your graphics card in your rig looking exactly like that 😵
Reply 17 of 22, by darkmercury
I'had got similar tproblem with a 7600gs agp on 754 mainboard with Via chipset . In my case there was an agp bridge incompatibility . I think that ground signal is not link at one connector for that you need a second cable .But you radeon is a Palit ?
I love retro stuff but sometime is very boring test it? 😈
Reply 19 of 22, by APFSDS
Here is pic with the heatsink on.
    1.51 MiB
    Front
    1.83 MiB
    Back
