"Delid" AMD K6?
First post, by Skalabala
Hi members 😀
I have seen people delid K6 CPUs for better overclocking potential.
But it is risky as you can chip it when installing the cooler.
I was wandering about delid and then put new paste like Coollaboratory Liquid Pro and put the lid back?
My idea is to maybe put a copper lid back. 😊
Reply 1 of 39, by Jade Falcon
Rank BANNED
BANNED
Don't use Liquid Pro or ultra. If you do this use something like liquid copper or mx7. Liquid ultra and pro will eat the ihs.
Anyway your better off with a better heat sink. Like a socket A heatsink
Reply 3 of 39, by Jade Falcon
Rank BANNED
BANNED
It's called cpu deliding or cpu delid.
It's very common with some CPUs for overclocking and benchmarking.
http://www.overclock.net/t/1313179/official-d … dded-club-guide
Not really worth it on a k6 if you ask me. We have socket A heatsinks nowadays and much better tims. No point in deliding one unless if your were going for a world record over clock. Even then there is tec chillers
Reply 6 of 39, by meljor
My k6-3+ is delided, bought it that way. It can do 6x100 and i didn't try it any further. But i don't think it will go any higher than a ''normal'' one.
As has been said: we have great coolers now and these are mobiles so heat will not be a big problem.
Reply 7 of 39, by havli
Heat is not the limiting factor for OC of any K6... except maybe the 250nm K6-III. Ane even then is the ~50 MHz gain worth the risk of killing perfectly good CPU? I don't think so.
Reply 9 of 39, by Jade Falcon
Rank BANNED
BANNED
License to this guy. He knows his stuff. Your problem is probably voltage, ram chipset or a problem with a PCI card if you have a Anthon heat sink on the cpu.
Reply 10 of 39, by stamasd
Go for liquid cooling.
With liquid nitrogen if possible. 😁
Does anyone remember those videos where they plunged an entire system (well apart from the PSU and drives) in a box filled with liquid nitrogen, and the crazy overclocks they got? The only problem is that it will destroy the system eventually.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 11 of 39, by Ampera
Eventually if you do that, the components get too cold to even boot anymore.
The slightly more reasonable, but still bat crap crazy idea is to dunk an entire system into Mineral oil.
man I should do that with a 486-DX4-100/120 build, get a tank, and just have the mineral oil passively cool it all. Maybe add a fan to circulate the oil.
Reply 12 of 39, by mrau
i have never seen any actual measurements showing better cooling in those circumstances; i believe the oil still has to be moved quickly in order to help the cooling process; imho just for shows;
Reply 13 of 39, by Ampera
Not true. Mineral Oil can take heat away from a surface better than air. It's a common coolant for lots of stuff.
Reply 15 of 39, by Jade Falcon
Rank BANNED
BANNED
mrau wrote:
that s not even an answer to what i said; also air is most often used as coolant, hence it must be an even better coolant than mineral oil;
And Toyota is the most used car there for its the best car... 🤣
Air is the most used method for cooling as it cheap, easy and gets the job done.
Oil submerging can be better then air but can also get hotter in the long run. It's better for when you use the system for shot time frames. Longer run times and your need a heat exchanger. Old submerging also costs a lot and mucks up your pars and as such is not really used much.
LN2 and DICE can hit sub zero and then some, Dice is around -50c. Tec chillers can get around -10c and liquid is around 45-50c full load with a overclocked 120w cpu.
Not sure about the temps reached with LN2 as I never used it before.
typically you don't plunge a system In LN2 but fill a pot/pipe with it that's attached to a cpu/gpu.
Reply 16 of 39, by stamasd
Except you run into problems with condensation/frost at the thermal interface and around it if you do so. By submerging the whole motherboard in LN2 you avoid water condensing and potentially shorting adjacent traces. It's a problem with any cooling system that decreases the temperature below the dew point of the surrounding air.
And no, don't even think of covering the whole motherboard in putty. 😵
I/O, I/O,
I/O, I/O
Reply 17 of 39, by mrau
i would kindly ask that you first understand the conversation and then comment;
Reply 18 of 39, by petro89
I absolutely agree with this...thanks to personal experience 😒
*Ryzen 9 3900xt, 5700xt, Win10
*Ryzen 7 2700x, Gtx1080, Win10
*FX 9590, Vega64, Win10
*Phenom IIx6 1100T, R9 380, Win7
*QX9770, r9 270x, Win7
*FX60, hd5850, Win7
*XP2400+, ti4600, Win2k
*PPro 200 1mb, banshee, w98
*AMD 5x86, CL , DOS
Reply 19 of 39, by yawetaG
In fact it may end up so cold that less resistant materials may shatter in a million pieces with only a little tap. Including any body parts in the way of a substantial leak.
