First post, by kva
I hope I am not breaking any rules with this topic, if so please let me know and be merciful 😁
Back to the topic - I have tested Celeron 220 (original clock 1200Mhz) vs Celeron Tualatin 1200Mhz. Same brand, same clock, six years of difference. Results are pretty interesting. Text is in polish but charts are self-explanatory. Hope you enjoy.
http://kva.pl/index.php?link=artykul&id_a=6
Celeron Tualatin vs Celeron Conroe at equal clocks
Pentium Pro 256k vs Pentium Pro 1M vs Pentium II Overdrive!
VIA C3 vs VIA C7
My website all about old hardware
Reply 1 of 8, by bhtooefr
Some of the tests, the Merom clearly massacres the Tualatin.
Some tests, though, it's surprisingly close... I wonder how a P3-M 1200, to match the L2 cache, and get the FSB closer, would do.
Reply 2 of 8, by kva
It is the matter of instructions. When SSE2 is used Tualatin has no chance. But in plain x86 the difference is not so big. The same situation will be with P3. But some day I will make that comparision 😀
VIA C3 vs VIA C7
Reply 4 of 8, by kva
Well... It is only CPU "review", GPU on Celeron 220 board sucks. Both in terms of speed and compability. So if you want to play old games old hardware is better for sure.
VIA C3 vs VIA C7
Reply 5 of 8, by mrau
but you don't have to use the onboard gpu or do you? my impression from old times is i was always missing cpu power/ memory and storage performance; a stronger gpu only improves up to a certain point; responsiveness is almost alway improved by cpu only;
Reply 6 of 8, by SPBHM
interesting test
memory performance is also not even comparable as expected (DDR, high and quad fsb)
also, the 661 is probably not one of the faster chipsets for it, I think even 945GC would have a decent performance lead for memory performance.
well, at the end of the day the 220 is a dual core with one core disabled, a CPU well capable of running at 2.4-3GHz but sold at 1.2GHz
the potential CPU on that die wouldn't even be worth comparing to the Tualatin, but on this low cost/power configuration it made for an interesting competitor in some of the tests, interesting to look for "IPC" improvements and such.
Reply 7 of 8, by kva
That was my goal 😀
VIA C3 vs VIA C7
Reply 8 of 8, by kva
What games should I use to compare this CPUs? GPU will be GT 8500 PCI (Sparkle) so not very powerful but usable.
VIA C3 vs VIA C7
