Graphics card question Pentium one
Reply 20 of 30, by kalloggs40
dondiego wrote:
It's a cut down version of the trident blade xp with 64 bit bus like the t64, i guess the name comes from the 16 mb onboard ram. If i'm not wrong will give voodoo 2 class performance.
You are correct t16 and t64 is a cut down version and are pretty rare especially the pci version. It was a last attempt by Tridents 3D turbo Blade. To go from 110mhz to 144mhz and 166mhz. The T16 must be the 144mhz i suppose and t64 the 166mhz?? Many forums in other languages are also looking for that t16 card including some facebook graphics card groups from poland.
Reply 22 of 30, by dondiego
The blade 3d turbo was voodoo 1 class hardware, these were next generation designs. Blade xp4 was a failure and later blade xp5 came as xgi volari v3 (drivers identified them as trident).
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 23 of 30, by feipoa
It is painful to see in that manual how they are using a PIII 800. Makes me wonder if the card is just acting as a frame buffer and the CPU is doing all the work. I was actually wondering if I should buy the last card to test it out on a PCI 486. It is Trident after all. The only place Tridents show up are on 286, 386, and pre-PCI 486's.
Reply 24 of 30, by kalloggs40
Love studying video cards I look up those failure models thanks.
Reply 25 of 30, by kalloggs40
Gotta love that 🤣 you made my day. (Last of the year here actually )
Reply 29 of 30, by Scali
j^aws wrote:
The packaging says it is a DX7-class GPU, so when it says it needs a PII, it probably requires the FPU power for TnL.
Yes, and/or MMX I guess.
Perhaps it would actually work on a Pentium MMX, but they deemed it too slow to be of any use.
Such system specs are usually quite arbitrary, and are not really an indication of the lowest configuration that would lead to a technically working system, but rather something that delivers a worthwhile user experience.
Reply 30 of 30, by devius
Trident 3DImage 9750 are also quite common over here on Pentium II era machines.
