First post, by Nipedley
Hey guys
I decided to upgrade my 486 system, so I grabbed an AMD 5x86 133. My board supports the DX4 and P24T (Pentium OverDrive) so I figured it wouldn't be an issue, apparently not!
It won't post at all. I set the jumpers for DX4-100, set the DX4 multiplier to 2x (also tried it at 3x which made no difference) and the voltage to 3.3v (again, also tried it at 5v later just to be sure also no difference)
All I get is a black screen, keyboard initializes but that's it. No POST boop, no life. Looks like I'm stuck with getting a DX4-100 instead, unless any of you guys have any suggestions? Thew my DX2/66 back in (and changed the requisite jumpers) and all good once again. Jumper settings etc. are here; http://stason.org/TULARC/pc/motherboards/D/DA … 86-EXP4044.html
Many thanks!
