First post, by member
- Newbie
HI
it's about pcb mark ing on the Motherboard Temperature Sensor Locations Negative temperature coefficient (NTC) Thermistors Chip place s by brand name s
Ambient (aka chassis) Thermal Sensor is located at the lower left corner of the motherboard, directly under the "Super I/O" chip and have code TRMB1 😎 Thermal Resistor Mainboard 1
https://www.google.bg/url?sa=t&rct=j&q=&esrc= … JPSyMXZ2_L6nhMw
ASROCK K7S41GX 😎
Service Manual 😎 http://www.s-manuals.com/motherboard/gigabyte_ga-8i915me-gl
Gigabyte pcb code is RS- RESISTOR SYSTEM
Asus P3B-F REV. 1.04 pcb code is RT1;2 Resistor Thermal
Multilayer NTC Thermistors Series: ERTJ0ER682 😎
