First post, by petieken
Hello everyone,
I've been lurking for a long time, but this is my first post.
I have a PVI-486SP3 rev 1.2 with two 16MB 60ns FPM sticks, 512KB cache, CF as hdd through Cf-IDE adapter, S3 Virge/GX with 4MB memory, SB Pro2 CT1600, Roland MPU-IPC-T and Gravis Ultrasound rev 3.4.
It's been working fine (except CTRL+ALT+DEL didn't work, nor software reboots) up until yesterday. I was going through my soundcard stack I've accumulated over the years and thought I'd try out the Creative CT-1920 AWE32 upgrade card (basically and AWE32 without the SB16 part).
So I plugged it in and booted up. The PnP bios recognized the card and everything else booted without problems. I put in the driver cd for this card (downloaded from vogonsdrivers) and followed installation procedure, it said to install the PnP manager first (CTCM), which I did.
Then stuff started to go wrong, I got an EMM386 error. So I reboot, the screen which shows hard drive, memory and cpu information was all garbled (weird characters and smiley faces). The system hung, so I pressed thr reset button again. Now it booted again, but the system hangs when config.sys loads CTCM. From this moment I noticed the keyboard is not responding anymore, because I wanted to reboot and pressed F5 to skip loading drivers.
I removed all cards from the system except the vga card, but keyboard is still not responding. I changed autoexec and config to REM everything by plugging the CF card into my other pc. It seems everything functions ok except the keyboard. I touched all IC's on the mainboard and noticed all are cool/warm except the AMIKEY-2 keyboard controller, which is hot. I can keep my finger on the chip for 5 secs max.
I removed the keyboard but the chip stays hot.
Is it possible the CT-1920 damaged the AMIKEY chip? Any ideas or tips?
*Asus PVI-486SP3 | Am5x86-133 | 32MB | Promise Ultra66 | 8GB CF | S3 Virge/GX 4MB | SB Pro2 | GUS Classic | Roland MPU-IPC-T
*Gigabyte GA-7S748 | 1GB | GeForce FX 5950 Ultra | Turtle Beach Santa Cruz
*Roland CM32L | Roland SC-55mkII | Yamaha FB-01
