I'm surprised there aren't any more floppy defenders on here. 😀 Floppies were the most practical method of file transfer until Windows XP era. CDRs were one time use, and expensive back then, and CDRWs were slow, expensive, and didn't work on all CD drives. USB drives didn't become really convenient until XP came out either. Windows 2000 would yell at you every time you tried to unplug one without "safely removing hardware," and Win98 required drivers to recognize your USB drive. And before that, forget about it. Besides file transfer, OS installs were nightmares without a working floppy drive. I guess Win98 supported installing from a bootable CD, but you had to have a BIOS that supported booting from CD, which was rare back then. By far the most common method of OS install in Win98 and prior would be to boot from floppy and then load the CDROM drivers. I guess that's why uxwbill on YouTube says that it's not a real computer without a floppy drive. 😀
My computer professor in college required submitting work on floppy disks, and that was 1998 or 99. But I went to a retro college. 😀 He also said about floppy disks, "Use it once then throw it away." I guess he had had too many bad experiences...
