First post, by tikoellner
- Member
Sorry for my ignorance (again).
I recently set up a retro rig that is based on ASUS VL/I-486SVGO motherboard (rev. 1.2.) with 486DX2 ODPR. As you all know, this board - contrary to VL/I-486SV2 - is not widely known and you can't even get a manual for it anywhere on the web.
It works very well and I get nice benchmark results. My only concern is about HDD support. In BIOS you can only see single IDE channel. When I install the controller that has two channels, it simply makes no difference.
Is this normal for a decent 486 VLB mobo to be limited in this respect? Or maybe I can enable the second channel somehow? I would really like to install two disks on separate channels.
