First post, by buckeye
When I turn my XP rig on it will boot for a few seconds then shut off. I'll wait a few then turn it on again and it'll boot up fine. This happens 90% of the time, other times it'll boot on 1st attempt. This has been going on for over six months, I just put up with it. It runs fine, no freezes or anything. All parts were picked brand new or NOS at least, the PS is a new 500W Thermaltake so don't think the issue is there. Anyone seen this behavior before? See my XP sig for part descriptions.
Intel D865GL Pentium 4 2.4ghz. 512MB DDR 400 Quadro4 900XGL 128MB SB Live 5.1 500W 98SE
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Reply 1 of 12, by clueless1
After it's been on for awhile, if you shutdown and immediately turn back on (not reboot), does it ever shut off before completing bootup? If you're not sure, try testing. Leave it running about 30 minutes, then repeatedly shutdown and turn on. See if it ever exhibits the unwanted behavior.
Reply 3 of 12, by Nvm1
Usually this kind of behaviour comes from either motherboard or PSU.
Even if the PSU is NOS it is still possible it has some cold start problems, so if possible switch it with another one.
Can't hurt much and easy to test.
Also make sure everything is grounded well, specifically to the back panel of the case. Had a strange boot issue a while ago with somebodies build and after touching the back of the machine I got a schock. Grounded everything by reseating the cards and after that the machine Always booted fine.
If none of this fixes it I would try it with another HDD and if that doesn't help then my guess would be a motherboard issue/feature.
Reply 4 of 12, by buckeye
Yep, got it running for awhile and then turned it off and it restarted no problem. Did this several times, so evidently it only shuts off initially after a "cold" boot. What would cause that?
Reply 5 of 12, by Frasco
Same thing is happening with a Fatal1ty FP-IN9 SLI and a OCZ Fatal1ty 750W PSU.
(with or without the case)
I just can't reproduce the problem right now ** in another front. Maybe later.
Sorry to give you wrong advice as I thought your OS was freezing or loading "forever".
It's clearly a hardware problem. I'll keep an eye on a solution over here.
Reply 8 of 12, by buckeye
Opened it up and noticed there were (2) holes on the mobo w/o screws. Took care of one but the other doesn't line up with any back plate hole. Would this create the boot problem? The PSU was brand new when I bought it and the mobo was NOS, wouldn't think it's a capacitor issue. But in the event that's the case I'll just ride it out till it dies, this has been going on for almost a year.
Reply 9 of 12, by clueless1
It would be interesting to see if you run the system on a workbench (outside of the case) if it behaves the same.
When I first got my 486, I had a weird issue with it working fine on the bench, then not posting when I got it in the case. I convinced myself it was a grounding issue. Then I accidentally discovered the real issue, and it had nothing to do with grounding. 😊
The point being, maybe it's time to assemble it out of the case and see if the issue still occurs.
Reply 10 of 12, by buckeye
Yes, when I get time that'll be the next step. Gonna have to hunt down a "power switch button/cable" to plug into the board.
May also just order another board (better quality) if only for testing purposes.
Reply 11 of 12, by Jorpho
All you need to do is touch the two power switch pins with a paper clip (or anything else conductive you might have kicking around).
Reply 12 of 12, by Tetrium
Flatbed screwdriver is also an option. I'll always have one nearby anyway 😜
And one with a plastic grip so I'll never electrocute myself and I like the firm grip it has.
Paper clips folded outward are also handy for making optical disks eject from non-powered optical drives.
My retro rigs (old topic)
Report spammers here!
