First post, by SilverGreen93
I have a problem with my Windows 98SE computer build.
Using the 5ALi61 motherboard, AMD K6-II 400MHz, 256MB RAM, ATi Rage128 PRO, 1 HDD (SD Card) and 1 DVD-ROM on Secondary IDE.
I see in My Computer the DVD-ROM listed 8 times. Also in Device Manager is also listed 8 times. What's the matter?
Has anyone encountered the same issue? It seems it works fine for the HDD, but only the DVD/CD-ROM is listed 8 times. I installed the official ALi drivers for Win9x
If I use the DVD-ROM, all 8 show the same content.
Here are some screenshots:
(Please ignore drive L:, it is Daemon Tools)
Also, if I enable DMA for primary hdd, the PC hangs quite often when reading from disk (eg, starting a game). Without DMA it never freezes, but uses 100% CPU at disk access. Maybe the drivers are bad? I cannot find other drivers.
Thanks!
