The PSU Matchup Thread
Discussion about old PC hardware.
Re: The PSU Matchup Thread
Postby Richo » 2017-11-10 @ 23:32
CkRtech wrote:What caps does it have in it? Not TEAPO, right?
Would have to check to make sure, only took a peak and cleaned the PSU before I needed it as this is now my only heavy 5V PSU not in build in a active system. It only has a few caps so cheap recap :lol: if I recap it. It was filled with brown caps so it is likely.
All caps from that era are bad so I recap stuff I want to use for prolonged periods on forehand.
I read some good things on Enermax their PSU in general so I might start using it.
TX97-XE, P55C, S3Virge, Voodoo, AWE64
GA-60XT, Tualatin, Albatron Geforce4 4200TI
A7N8X Deluxe, Barton, A9800 XT
Strix X99, Haswell-E, Gigabyte Aorus Pascal
User avatar
Richo
Postby gdjacobs » 2017-11-11 @ 00:09
Brown caps? Better hope it's not Su'scon!
User avatar
gdjacobs
Postby Richo » 2017-11-11 @ 00:55
Ah yes teapo are green ones. Nah most are either black or brown. My current hiper had teapo and other Chinese crap caps. The antec on my PIII had a mixture of dunno what was like rainbow. Have to admit though that the Enermax has the fewest caps if all my PSU. Since I am no expert at all in PSU I can't say anything about the quality other then that the hiper looked cheapest (but a ****load of caps 36! Was expensive to recap :dead: )
User avatar
Richo
Postby vvbee » 2017-11-11 @ 13:01
kenrouholo wrote:Enermax EG375P-VE: Would still power most basic machines today (no high power GPUs or server machines, of course).
I used an enermax eg365p-ve to run an intel haswell system 24/7 no probs, including with frequent overnight cpu and gpu rendering. Only issue was no sata plugs.
User avatar
vvbee
Postby SpectriaForce » 2017-11-12 @ 00:22
I have never had any problems with failing capacitors in ATX power supplies in my own pc's. Only with some 80's IBM pc's (and other systems of that age) I've had problems (non ATX though). The thing to look for in ATX power supplies is weight. The higher it is, usually the better the components are (also applies to for example flatscreens and audio equipment). I have recently inspected my Magnatek power supply in the IBM Aptiva (which is a 20 years old consumer pc) and it stil works and looks great. Same applies to the Astec power supply in my even older AST pc. Those have decent premium brand capacitors. If you really want a power supply that never gives problems, then take a Seasonic. They are expensive, but for good reasons.
Win2K keeps the headache of an activation loop away!
Custom Asus TUF X299 Mark 1
Custom Asus P5E
Custom Intel DH61AG
Custom HP XW6200
Custom PCCHIPS M935CG
Custom IBM Aptiva 2176-442
Custom AST Bravo LC 4/33s
User avatar
SpectriaForce
Postby SpectriaForce » 2017-11-12 @ 00:27
Nichicon also made brown caps... not necessarily a bad sign. Now if they have brown residue on top, that is a bad sign!
Custom Asus P5E
Custom Intel DH61AG
Custom HP XW6200
User avatar
SpectriaForce
Previous
Return to General Old Hardware
Who is online
Users browsing this forum: Baidu [Spider], cskamacska, Google [Bot], matze79, OldCat and 11 guests
