First post, by iKarith
- Newbie
I recall that in the later socket 5/7 days, boards began featuring a turbo LED connector, but often lacking a turbo switch connector. Take for example this EFA Viking 3.
If you llook at page 8 of that manual, the front panel connector lists a turbo switch connection. Next to that is a pair of unlabeled pins (which is odd because this connector has no pins anywhere else that has no connection). Given the rest of the connector and the lack of pins where you have no connection, I have a suspicion that's my turbo switch connector. Is that likely? Was it common to include a turbo switch on boards of this era without labeling it?
For the two people that noticed I was previously discussing an Acorp board, yeah--the board seems to be unable to boot. As I don't even know where to begin troubleshooting that, I decided I was better off trying a different board.
