First post, by bluejeans
A timedemo had vanilla as 19fps and doom95 as 15, but it didn't appear to run as fast as possible, like in the benchmark pack on these forums.
Reply 2 of 4, by derSammler
It should run faster, as it can make use of hardware acceleration through DirectDraw. However, with no info about the hardware you are running it on, there's nothing one can tell to help you with your question. Having said that, a graphics cards with 2d hardware acceleration is needed at least to get a speed-up.
Reply 3 of 4, by FGB
It would be intersting to measure the actual benefit of using Direct Draw technology. Apart from that Doom95 supports resolutions up to 640x480 which may need more CPU power than the 320x200 DOS-version.
www.AmoRetro.de Visit my huge hardware gallery with many historic items from 16MHz 286 to 1000MHz Slot A. Includes more than 80 soundcards and a growing Wavetable Recording section with more than 300 recordings.
Reply 4 of 4, by bluejeans
Pentium 133, 48mb ram, onboard video.
