First post, by bluejeans
Technically it seems possible, drop your cpu speed a certain amount (I have a lot of proprietary systems that make it impossible to adjust ratio or cache), run passmark performance test, and adjust until you get the cpu speed score of the cpu you want to pretend to have. Only problem I've had is the system or games not functioning if you drop it to 10% of normal speed though. Oh and obviously, needing a system that can amicably run win 7 in the first place!
