First post, by kaputnik
- Oldbie
Looking for a case for a new build, specifically for a retro LAN party, so this time I won't settle with the usual CM Elite 361, want something period correct.
My preferences:
- ATX form factor. The mobo is a MSI MS-6119, it's the same size as just about all 440BX boards are.
- Off-white, want the 90's look.
- As small/slim as possible. This is important. Planning to install a 3.5" HDD, a CD drive, and a 3.5" FDD. Ideally I don't want any empty drive bays. Will sacrifice the floppy drive if there are smaller alternatives without floppy bay.
- Clean, minimalist design if possible. Small size has priority though.
- Both tower and desktop cases are fine. Would prefer a desktop case, but it would have to accept standard ATX PSU:s and mobos, might be hard to find.
So, do you guys happen to have any ideas of specific models to look for?
