First post, by Baoran
When it comes to pentium motherboards and pentium cpus in 100-120Mhz range, does it make a speed difference if you compare a motherboard with 256Kb of cache and 512Kb of cache?
I have 2 pentium AT motherboards. One of them is socket 5 motherboard with 256Kb of on board cache and the other one is a socket 7 motherboard that has 512Kb coast cache module. There are things about the socket 5 motherboard that I like more compared to the other one, but I would probably still use the socket 7 motherboard if having more cache matters even if the cache is in a separate module.
