Cheap AT/ATX Test Bench?
Reply 21 of 23, by PDXSonic
I've been using a Cooler Master HAF XB Evo. While a very large cube case, it the sides and top are easily removable and it has fairly good access to the components. Probably not an ideal test bench but it is what I had on hand.
fJlUexwLK5D0ho4ZUXkCecnUo0zNo4usuFpRdqpB3OkoD4GQo5WWDuH6tfy0xSQGewdjYlLFvoQL7hX_4C66127rXfXIaKMEWtcQyS4MYpa_W_sSrr4r9yDyuc8Zo4HMZJexYDWY_GKDNoDUNHSUG38x4pm85kzh4EtqKARGNu5i9eIxzylIRnGvHbaVrZ1VpULExJoWla-t2qbxKSuc6FB3PTepMYf_jg5AcJ8NwboylkdgA7iTRDGSk9jdpw68XgOJ9K0lH9qxZf_cEWinjOXbqG1Rn4RoJ3dk-9JI7vgsO9LyKQzVOvC6eBO12_vnIoUm5zwfP6mdSjWzW3mWXWqn89r3c7LYDQIbBxeLzq2D3s7KqmUPjch3YWJQCKOZqFWWmm_S1oac2V8qB_4rVjSFabinVEOLkfIGPgs6dj_ci7mDb-lu0lSGydSOOgkNalKvovWXrgq2z1LVIHr0vgColyHyKi1wvKPybBjekNSLGA_seB0ouuRaWUR5RHkmUC2zwcVPHwiicFSWzPc4JjCp2g1i1lRBk5-gTIIsgT4vc9vop2FaVX7AvKrRmV5JefcbQoHaVNQ_p80JUyPnRoPA0_S7nXKR14sNzDo=w402-h535-no
Reply 22 of 23, by Stiletto
Hi, this image doesn't display.
See here for my procedure for posting from Google Photos:
Re: Televideo Telewave Audio 32 sound card, questions about its onboard wavetable ROM
do the Fandango!" - Queen
Stiletto
Reply 23 of 23, by arncht
not cheap, but small 😀 Streacom BC1
https://youtu.be/z-liULfh4CI?t=135
i tried to simulate with at boards: the asus tx97 and the gx4 486 vlb
302.68 KiB
250.24 KiB
Overdoze of the demoscene
