First post, by AlucarD86
So I recently bought two Diamond Monster 3d II 3dfx Voodoo 2 8MB cards and they are both in mint conditions and came with the passthrough cable and the ribbon connector for SLI.
Now I have noticed that there are 3 main chipsets on each card which arent cooled at all, not even passive cooled, same as with the matrox M3D
What I want to know is, can someone recommend a decent cooling solution for those chipsets on the Voodoos and the Matrox M3D ? since its 1st of june and summer and its getting pretty hot here I was wondering on how to cool them properly. I already have my case open but some advice on how to apply a passive cooler to those plastic chipsets and what pads to use would be very helpful.
PC Setup: Mainboard ASUS CUBX | CPU Intel Pentium III-S Tualatin 1.4 GHz | Memory 780 MB SDRam | Soundcard Creative SB Audigy SB0160 | GPUs Nvidia FX5900 Ulta Matrox M3D PCI | HDD 2x40 GB WD/Seagate | OS Win98SE and WinXPSP1 in dual boot
Reply 1 of 9, by spiroyster
Personally I have never seen a heatsink on a PCX1/2 PowerVR chip. Doubt you'll need one (I don't have one on my PCX1, although that probably won't run as hot as PCX2).
My Voodoo2's don't currently have any heat dissapation so would be interested to see what others say (I don't really use them much anyway tbh). I was just thinking about getting bog standard heatsinks that fit the chips (3DFX chips and RAM) and sticking them on just to make them look badass at least.
Reply 3 of 9, by AlucarD86
the Matrox M3D gets pretty hot especially when you use faster CPUs like a Pentium 3
Reply 4 of 9, by Munx
My Voodoo cooling solution is 35mm heatsinks attached using 3M thermal tape. A 120mm front fan provides a bit of airflow.
My builds!
The Underdog - The budget K6
Reply 7 of 9, by chinny22
I did a bit of rough research on temperatures a while back
Voodoo 2 Temperatures
Stealth V2 Cooler are the period correct coolers
But as long as you mount a fan somewhere and have airflow over the cards you'll be fine.
Reply 8 of 9, by AlucarD86
looks like a custom cooler ??? is it taped onto the chipsets directly with powertape ?
Reply 9 of 9, by psycotrip
id measure the chips you want to cool and look for adhesive heat sinks on ebay that are the correct size.
I measured my voodoo2, I don't have a nec card
http://www.ebay.com/itm/Gold-Tone-28mm-x-28mm … p8AAOSwxu5ZEZ9d
http://www.ebay.com/itm/2pcs-Lot-28mm-x-28mm- … 5kAAOSwQTVV7p3Z
your welcome
btw this is a Compaq oem voodoo3 1000 16mb with sgram that I added heat sinks to
    4.42 MiB
