First post, by PoulpSquad
Greetings,
I've made some progress with my retro box, but I'm having a hard time solving the issue I now submit to the sagacity of VOGONS' dwellers.
I'm trying to build a computer to run DOS and Windows software from 1991 to 2001 time frame.
It consists of:
AOpen AX63 Pro motherboard (VIA 693A/596B, AGP x2, 5x PCI, 2x ISA, 2x USB 1.1)
Intel Pentium III 1 GHz (1000 MHz, 133 MHz FSB, 7.5 multiplier, 256 L2 cache)
2X 256 MB RAM sticks (Kingston KVR13364C3/256 3.3V)
Hercules Terminator/128 3D "GLH" (S3 Trio3D 365 with 8 MB SRAM)
Orchid Righteous 3D (Voodoo Graphics)
Sound Blaster AWE32 (CT3900 ISA, 2x 16 MB)
Roland MPU-401AT
Intel PRO/100 S Server Adapter (Fast Ethernet 100BASE-TX)
Wester Digital Caviar SE 160 GB ATA (WD1600AAJB, master on primary channel)
Sony CDU5212 (52x ATAPI CD-ROM, master on secondary channel)
Gotek floppy disk emulator
Corsair HX1200i PSU
I'm trying to play games on Windows 98 Second Edition (English US).
I have about 140 GB worth of CD images in BIN/CUE format I'd like to mount with DAEMON Tools 3.47.
I can't fit all of these images and install the games on the same disk, as space is limited.
I don't have access to biggers ATA hard disks. I dislike the idea of buying second (third?) hand hard disks.
So far, I tried:
-storing them on a SD card plugged to an SD to USB adater, but it is much too slow to be usable (audio skips/game pauses for 1-2 seconds everytime the image is accessed).
-storing them on an external hard disk plugged through the same USB 1.1 interface. It was better, but still way too slow (same symptoms as with the SD card).
-adding a second hard disk, but because of the way DOS works, it automatically becomes disk D:, and breaks audio on many games that expect the optical drive to be D:.
-adding on of those VIA USB 2.0 PCI adapters. So far this has not worked at all. I ordered a different model just for kicks, but I'm not very optimistic...
-connecting to my main Windows computer (Windows 10 Enterprise 2016 LTSB without domain). Both computers are in the same Workgroup. I couldn't manage to access a shared folder so far.
-replacing the IDE hard disk with a SCSI320 300 GB. hard disk. It's fast enough, but the controller's BIOS eats too much upper memory and I can't share files with my main PC.
-compressing the images, but I have yet to find a compressed format that works with DAEMON Tools 3.47.
-using an ATA to SATA adapter. These things are from hell and don't work (for me) at all.
-adding a PCI SATA controller (Adaptec with Sillicon Image chip). Had random read errors.
-plugging an external hard disk to my router. The router sees the hard disk and shares its content ok, but my Windows 98 box doesn't see it.
-setting up an FTP server on my main computer and download images as I need them. That was pretty desperate...
-looking for an ATA SSD on eBay/Amazon. I couldn't find any big enough.
Please post your suggestions, as I'm running out of ideas...
Thanks a bunch for your patience.
Cheers!
*edited for typos
Reply 1 of 17, by Jorpho
I am very confident that there are few games that will insist on the optical drive being drive D. There are games that break on systems with more than one optical drive, but that is a different matter.
In any case, there are utilities that let you re-assign drive letters, so that shouldn't stop you.
In theory, NEC-based cards work better than VIA cards.
Which USB 2.0 cards for old motherboards
I wonder if Firewire is worth considering? I've never had a Firewire drive.
There's been enough discussion of this out there. Frequent advice is to enable NetBIOS over TCP/IP, install the appropriate networking update in Windows 98, and enable NTLM compatibility.
If all else fails, you might have better luck running Linux in VMware and setting up a networking share there.
Of course you know that as the years go by you're probably only ever going to touch a fraction of that.
Reply 2 of 17, by PoulpSquad
Thank you Jorpho,
Very few will indeed fail running, but a few won't output any CD audio.
It just realized that games with CD audio tracks are rare, I'll probably copy the ones that have audio tracks on the hard disk and leave the rest on SD card.
Could you please tell me of one such utility? I know something like that was possible when using compression software like Stacker or DoubleSpace.
viewtopic.php?f=46&t=39172
Thanks for the link, I'm going to check it out.
*Update*
I just got myself this thing: https://adaptec.com/en-us/support/_eol/usb_ad … ers/aua-3100lp/.
Hopefully it will work better than the VIA card I had.
I agree, there has. Every time I tried to connect Windows 98 with anything "modern" I ended giving it up.
I wonder how would those external Ethernet hard disks fare? I have seen cheap ones but I'm not sure it would work.
To be honest, the older I get, the less games I play... I'm probably enjoying solving silly riddles like these more than playing actual games!
Nevertheless, I still love to play the occasional Windows Commander 3 or Civilization 2 game, so I still have some tinkering to do!
Thanks for your tips, I appreciate it.
I hope others can chime in with more ideas!
Reply 3 of 17, by Sammy
How about writing a Batsch file with menu where you can choose the image you need. And that image is then copied to your fast HDD.
BTW: if you use an SD adapter can you enable DMA for it?
Have you thinked about a CompactFlash adapter?
If you connect your HDD to your Router and Share it via FTP it should be possible to download the Image via a script (like the batch-file above)
Or just put the images on a USB stick and copy the one you need to the HDD... there should be store for 5 to 10 Images on the fast HDD, i don't think that you play more then 10 games at the same time.
Reply 4 of 17, by PoulpSquad
Hello Sammy
Yes, I thought of that, and it is insanely slow. My "fast" hard disk is capable of transfering about 10 MB/s of data. The point is moot anyway, since USB 1.1 is only capable of about 1.5 MB/s.
Yes, but it didn't change anything at all.
I did, but not for this use. I tried a couple back when I wanted to use them as hard disk replacements, but that didn't work, and speed was about the same as the USB interface, maybe a bit faster (about 2 MB/s).
I tried that to circumvent the limitations of Windows' networking client when dealing with Windows 9x.
Alas, Windows 98 is not able to see the router on the network. Other computers (all with Windows 10) are able to access the shares on the hard disk.
You are right, and it sounds reasonable. Maybe I should just weed down all those images and keep 10 or so games. But come on, it's 2017, I'm sure I can do better than that!
I am quite intrigued by this bit of information Jorpho was kind enough to share:
What are those mysterious (to me, at least) utilities he speaks of? I've been looking for them but I haven't found anything yet.
Changing a fixed disk drive assignation would be awesome and solve all my issues, as it would allow me to use 2 hard drives and have a CD-ROM as D:.
I just got myself an USB 2.0 card with NEC chipset off eBay. I think it's my best bet, because I can have an SD card to USB adapter and change the drive letter.
On a positive note, I'm impressed how stable Windows 98 SE with Unofficial SP3 is. It didn't crash for a good 15 minutes straight!
Thank you for your suggestions Sammy, I sure appreciate it.
Reply 5 of 17, by Deksor
98SE doesn't see your router ? That's strange.
To avoid the compatibility issue between shares found on windows vista or beyond and shares on win9x, dos, etc machines, I took a raspberry pi (even the old B model with the 700MHz can work) and I created a samba share on it. This works flawlessly except for one little thing : under dos, long files names are displayed completely wrong (instead of having "yourfil~1.exe", you get "yfdhjie~g.exe" but everything still works so that's not a big deal, especially if you use win 98, then you won't have this problem). Then you add a wifi dongle on the rpi to access to your router. You can either choose to put your files directly on the pi's share if you have an SD card big enough or an external disk drive or you can also just mount the share of your windows 10 machine ... on the pi's share I did this because I didn't have enough room on my 32GB sd card and I can tell that this works great too ^^
One thing that you can do too is to configure your pi to route packets so it would still be connected to the internet (it depends if you put your retro pc on the same network as your modern one or if you're okay with plugging the pi directly on the ethernet port of your retro pc. If you just connect it to the same network as your modern pc, then your pi won't need any wifi dongle (mine does because my retro pcs aren't in the same room as my router)
But the fact that your 98 box doesn't see your router is really odd, are you really sure that the network card or the drivers are working properly ?
Reply 6 of 17, by PoulpSquad
Hey Deksor,
Sounds very interesting... I'll look into it with more detail if the USB 2.0 card doesn't work.
I think it is... It appears in the device manager, it's got a fixed IP, Microsoft client is installed, computer is in the same workgroup as the other computers in the house.
What is odd is that all the other computers see the router but don't see my retro box, but my retro box sees all other computers but not the router!
The more I think about it, the more I like your setup with Raspberry Pi.
Thanks a lot Deksor for a cool idea!
Reply 8 of 17, by Deksor
Just try to ping the ip adress of the router and with your win 10 machine to ping your 98 box and normally they will respond
Reply 9 of 17, by Bobolaf
Sounds like you are not having much luck. So much so I may wonder if you have another issue with your system possibly or I may just be over thinking things.
A good quality SATA card should work just fine. What SATA cards did you try?
I always had good results from CF cards for read intensive applications. I was always getting 30+ sequential read even with slow 233x cards. Random read was not to bad too. However CF cards fall flat on there face in random write operations as they have no cache unlike dedicated SSDs. Devices that use CF have cache built in to them rather than the media. It mades CF cards relatively affordable as fast cache was very expensive. For simply loading ISOs from I would say a moderately fast CF card would be perfect. I would be tempted to give one a try again. It's important to get them from reputable retailers as memory cards are by far in the way one of the most counterfeited electronic items and copies after often painfully slow.
If you do require more write oriented hardware perhaps another go with a IDE to SATA bridge is worth a go. Loads of people appear to be using them with no issues. You even get big reputable brands doing bridge chips like Marvell for this application. I would be surprised if a good quality bridge and SATA drive would not give you good enough performance for loading ISOs from.
Reply 10 of 17, by PoulpSquad
@Snayperskaya:
There are plenty of new/sealed 400GB IDE drives on ebay (at least US ebay) for ~30USD. That mobo should prolly recognize them without problems.
I couldn't find any here in Europe. I wouldn't have any problem purchasing stuff from the US, but customs are pretty slow (most of the time stuff gets here in about a week from the US, and then rots for up to 2 months in customs). That's before computing importation taxes, which can be hefty.
@Deksor:
It does, both ways. No lost packets. I suck balls at this...
@ Bobolaf:
I tried an Adaptec AAR-1210SA. It works for the most part, but causes random read/write errors (e.g. Scandisk running a surface test will detect bad clusters).
Also the card's BIOS takes 32 KB of upper memory, and the card does not support CD-ROMs.
I tried a Lexar Professional 128 GB rated at 800x and a Kingston Ultimate 32 GB rated at 600x.
I tried also putting a microSD card in a microSD to SD adapter, which I inserted in a SD to CF adapter, which I inserted in a CF to IDE adapter. That works, but is no faster...
They both work great on my main computer, but on my retro box they are limited by interfaces, either about 10 MB/s when using ATA ports or roughly 1.5 MB/s using USB ports.
As to boot from a CF, I never managed that stunt. I understand memory manufactures sell special "industrial" memories that can boot. The only difference, I was told, is that industrial CFs are fixed disks, and normal CFs are removable. Oh, and also industrial CFs are a couple of times more expensive.
I'm not thrilled by this idea, as I purchased half a dozen different types, and I could never format a drive completely in DOS with them.
I've heard from some reputable ones but they are either extremely expensive or hard to find. I'll keep looking for them.
Thank you guys for your help!
Reply 11 of 17, by Deksor
Allright so the network is working great, just that there are incompatibilities in how new and old computers communicate between each other I guess. But the basic stuff still works apparently (normally you can even connect to the internet. Try to ping google.com and it should respond too ^^). All you need is a "compatible" share which Samba can do
Here's my config file (it might have some security flaws though as it can let you access to files that are root's property)
smb.conf
2.57 KiB
47 downloads
Reply 12 of 17, by firage
I wouldn't do that with 98SE, unless it's the last resort. Using the first ~128 GiB of an IDE device or even multiple devices is fine, but going past that on any one drive presents issues for the IDE driver and disk utilities (besides the controller needing to support higher than 28-bit addressing).
My big-red-switch 486
Reply 13 of 17, by PoulpSquad
@ Deksor:
If I recall correctly Microsoft sabotaged any connection attempts to anything newer than Windows XP. Even Windows Server 2003 requires tampering to allow Windows 9x connections to a domain (https://support.microsoft.com/en-us/help/555038).
I'll try Samba, as it could be an option. Thank you for the the config file, I'm sure it's going to be pretty useful!
@ Snayperskaya:
This problem shouldn't happen on network shares I think?
Reply 14 of 17, by Karm
There should be really few games which needs the D: Letter as CD-Rom Drive Letter AND output CD-Audio...
There probably is just a problem with the driver or the connector cable from CD to the Soundcard.
Have a Dos/Win95 System with A LOT of letters and I think my CD ROM is K or so...
Everything worked fine with eg. GTA, Tomb Raider, Settler 2...
If you could name a Game which needs CD Audio AND D: as letter, please tell me so I will check it, if I have it.
(and if it is just one game, maybe there is a ini file you can change, or try to use
subst / assign)
Reply 15 of 17, by Jorpho
That's what I meant. Can you give an example of a game that will only produce CD audio if the CD-ROM drive letter is D: ?
The last time I had to poke at it, I was using something included with the Iomega Zip drivers, but I'm certain I've come across something similar before – even DOS utilities.
A quick Google suggests you can do it in Device Manager.
https://www.computerhope.com/issues/ch000038.htm
EDIT: Acht, that applies only to disc drives. I'll Google a little more.
EDIT2: Here we go: DRVEXCH. If you use it in your CONFIG.SYS, then it shouldn't interfere with Windows. Worth a shot, anyway.
http://freesoft.cyberside.net.ee/FreeSoft/disk2.htm#drvexch
Also Letter Assigner, which is a Windows program.
http://smallvoid.com/article/win9x-letter-assigner.html
Reply 16 of 17, by PoulpSquad
@ Karm & Jorpho:
I remember having problems with Quake and Hexen, and some Windows 3.x games, like Civilization 2.
Also some Microprose budget re-releases had a tendency crap out, maybe because of shody batch installers that assumed a CD-ROM drive as D:?
I'll have to install a couple of games and make sure I'm not having an Alzheimer's fit, and stop talking crap for a change...
@Jorpho:
EDIT2: Here we go: DRVEXCH. If you use it in your CONFIG.SYS, then it shouldn't interfere with Windows. Worth a shot, anyway. ht […]
http://freesoft.cyberside.net.ee/FreeSo ... tm#drvexch
Awesome! Thanks a lot, I'll give those 2 a thorough look!
I spent all afternoon looking for any hints, but all references were about how to change unit letters in NT's Disk Management, or tutorials about how fdisk works...
Thank you both for your help!
**EDIT**
Apparently that utility only swaps existing drives at boot up time, and doesn't work with optical drives.
I guess it's all we can hope with such an old operating system, thanks anyway for your time looking it up!
Reply 17 of 17, by PoulpSquad
I just tried to understand this problem I was having with games not playing audio tracks.
It appears you guys were right, it's got nothing to do with running them in a drive that is not D:. All those I tried so far work great on any drive letter!
It seems I was mystified by DEAMON Tools, as discussed here Re: Windows 98SE + Virtual CD Software + CD Audio.
I was having the exact same problem as Great Hierophant, but instead of Windows games not playing audio, it was DOS games!
I just sorted this by adding a Sound Blaster Live! (CT4830) and setting DAEMON Tools to output analog audio to it, and plugging the AWE32 output to the Live!'s line in.
Now I have both digital FX and CD audio, both in Windows and DOS games, no matter what drive letter games are running from.
