First post, by 386SX
Hi.
I got this mainboard (ADI?) TK8498F/GP 4N D24 with UMC 8498F chipset and in perfect state and it runs flawless with the ram I have (various 60ns and also one 16Mb 50ns one) with the DX2-66 cpu (Overdrive). The problems come with the Overdrive DX4 100Mhz I have that when installed is detected as DX-4-S 120Mhz cpu (?) running at 100Mhz correctly but games often crash with it, no matter the ram I use. It's not an heat problem cause I've a fan running on it.
Doom crash in timedemo randomly for example. There're many jumpers and I tried various config and it still recognized as above and nothing change.
Any advice to solve this?
Thank
Reply 1 of 3, by Deksor
Maybe try to update the BIOS if you can. My AP43 board was hanging at POST when I installed my 5x86 with the 4x multiplier set. However with the 3x multiplier it worked flawlessly. The bios was from august 1995 and the 5x86 was released only few month later. I updated the board with a bios from 1996 and then it works perfectly.
Maybe also since your previous CPU was a DX2 overdrive, it probably had write-back cache instead of write-through so maybe you board still tries to use the cache as write-back even though you DX4 might not support this mode. However I'm not sure that if this was true the computer would even boot so this might not be the problem
Reply 3 of 3, by 386SX
Problem with the bios is that I don't know if one exist. Even the brand of this mainboard is not sure.
