On the Zida, yes. But not on the new board, just keeps cold.
Jumpers on both boards are fine, triple checked. Although I don't understand the DRAM settings here http://stason.org/TULARC/pc/motherboards/T/TM … 4-VER-1-2A.html (but considering the seller used the ram I have here to test it and has the setting in the same location I assume it's fine)
What I might be able to do is check if the board works with the dx40, but I'd need someone that can tell me if I can actually use it on that board considering it's listing doesn't say anything about an AM486DX, just AM486DX4 and AMD enhanced.
Edit:
For some reason I now get error codes on the 4DVS when using the dx40, specifically FD and on rare occasions F9. F9 doesn't exist, according to the little manual. FD means "next programming the flash rom", which doesn't seem to help me with repairing it as far as I can see.
Also clarity edit.
Edit2:
1 motherboard is still non funtioning, (the one that gives F9 or FD). The other works. Apparently the CPU was faulty...
