pshipkov wrote on 2023-03-22, 07:26:
I dont have cpu removal tools, so your notes a bit ambiguous. But i think i understand what you mean.
Every PGA CPU removal tool I've seen has looked fairly similar. They were quite common in Cyrix and upgrade adaptor kits. These are mine and this is how they work. I'm showing the SXL2 interposer here:
If you install the PGA pins the other direction, no CPU removal tool will fit, as shown:
Also, if the pins are oriented that way, insertion and removal is much easier, yet the adapter sits firmly in the socket when inserted.
It may fit tight now, but over time and with many removals, you may be widening the female holes on your sockets because the pin diameter on the end you've selected is wider than standard. I have witnessed this first-hand and this was with socket diameters that were only 0.50 mm. You are using 0.58 mm when 0.43 mm is nominal.
Also, if some of the female pins in the ABS on a socket has a slight inset, your SXL2 adaptor's pins might not snap in. I've run into this on some sockets which had too short of pins. You don't get enough lateral (z-direction) contact area when the pins are too short. See:
Btw, where you measure for noise levels ? Can you confirm, so i do the same here for conformity.
Take measurement right on the VRM pins themselves using low-inductance probe, 10x. There should be photos of this in the thread a few pages back. x-scale: 100 uS, y-scale: 50 mV. Noise: Vp-p, auto measurement feature, or use manual cursor.
Last note - silk screen on these PCBs can easily crack and chip away.
It requires precise and gentle handling.
As I recall it, the silkscreen on Alpha1 was a bit more robust compared to Alpha2. Perhaps this is where some of the cost cutting went for the JLCPCB discount ($85/batch vs. $2/batch).
