Reply 1200 of 1217, by PC Hoarder Patrol
- l33t
PC Hoarder Patrol wrote on 2024-03-27, 11:22:ASROCK P4i945GC
Item is taken
Item is taken
Acer 1125 386DX-25 AT system up for grabs
FOR PARTS / NOT WORKING
It powers on but I hear no POST beeps, and there is no graphics card present to view anything on screen. It suffered from a battery spill disaster, but fortunately the battery was external and appears to have only leaked on the metal drive cage part of the case. I couldn't observe any corrosion/damage on the motherboard. Could possibly be repairable. You can see the extent of the corrosion/damage in the photos.
I did keep for myself the hard drive and the IDE/floppy controller card that you see in some of the pictures. There was no graphics card or 5.25" floppy when I got it, so these went missing a long time ago.
Includes basically what you see here: heavy duty case, MB/CPU, floppy drive, power supply, a couple of misc. I/O cards, ISA NIC, misc. cables, and the drive rails from the hard drive.
It's a big chonker so I'd really prefer local pickup instead of shipping, but I could try to source a sturdy box and packing materials if someone wants it shipped badly enough.
Just wanted to give an enthusiast a shot at it before it goes to the recycler or gets parted out further.
Located near Sharon Center, Ohio (44274).
XP: A64 3000+ S754 / 2GB DDR / 500GB SATA / Audigy1
2K: AXP 1700+ @ 1.61 / 1GB DDR / 120GB IDE / X800XL / Audigy 2ZS
98SE: P3 500 / 512MB SDR / 120GB IDE / V3 3000 AGP / Vortex2
95: P200 MMX / 32MB SDR / 3.2GB IDE
DOS/3.11: Acer 1120SX, 386SX-20
Edit: CRT is gone
CRT was picked up
386 parts PC and Fujitsu HDD from a couple posts back are still available
PM sent.
New pm sent. I only post here because we're not notified otherwise.
Got your messages. I'll look into that for you!
Must go for shipping price.
Ideally the 3 items at once.
That DTC SCSI is new in the box.
I very gently opened it by making a minimal cut on one side of the plastic wrap - for a brief functionality test.
pshipkov wrote on 2024-04-07, 00:17:That DTC SCSI is new in the box.
If it's not gone I'd gladly take this one (and other stuff if needed), are you in American continent?
Send me your address. Will ship on Monday. Yes, i am in NA.
pshipkov wrote on 2024-04-07, 06:29:Send me your address. Will ship on Monday. Yes, i am in NA.
Thank you very much for the quick answer, unlucky I'm in Europe, if I give you the address can you check how much is going to cost?
How about a 3D printed IO plate for an Asus TX97-XE? A new item for old hardware.
I recently modified an IO shield for a different board to work on my TX97-XE. My first print worked perfectly, but there was a line on the print I wanted to remove. So, I removed it, or so I thought, and printed a 2nd shield to see if it worked. Stupid line was still there. So, I shelved the edit until I have a day off to work on it. However, that means I have an extra TX97 IO shield I don't need. So...
If anyone in the United States wants it, I will happily ship it to you for free. It won't cost much more than a stamp since it's so lightweight.
Below is a photo of the plate. You can see the line going through the A in Asus. 😜
Retro Blog: https://theclassicgeek.blogspot.com/
Archive: https://archive.org/details/@theclassicgeek/
3D Things: https://www.thingiverse.com/classicgeek/collections
Hi all
I have a load of stuff to giveaway - see the attached photos. Some of it is a little random. You can collect from Bristol or I can post - but you pay the postage. UK only please.
Boxed software may not have license numbers
Dell SFF PC has a power issue
Floppy diks not tested.
Keyboards working, but missing keycaps
Media slice for for a Dell Latitude X300
Prt 2
Prt 3
Prt 4
Prt 5
Man, I would love those VideoSeven Vega VGA driver + utility disks since I have at least one of those cards. I saw "Bristol" and got my hopes up, but alas, Bristol UK is much farther away than Bristol, Tennessee.
Also, just out of curiosity... what is in the brown mystery box?
