First post, by Pabloz
old motherboards come with the combination CHS that is cylinder , sector , head. In some of those motherboards you have to manually put the numbers on the bios.
and after that you can book and fdisk the drive.
i was unable to find information online on how to obtain the Cylinder/Head/Sector of an specific compact flash card.
so if you buy a 256mb or 128mb CF card, how can you obtain the Cylinder/Head/Sector numbers that you need to input in the bios?
Reply 2 of 10, by konc
Run the attached utility on the machine you have the CF connected. Define nothing in BIOS, boot from a floppy and run it.
IDEINFO.zip
3.83 KiB
2531 downloads
I'm assuming that your question is about machines that don't have an auto-detect option in BIOS. In this case using the auto-detect feature of another machine to get the values is dangerous, unless you are absolutely certain what you're getting. Usually, not always of course, PCs with auto-detect also have LBA.
Reply 4 of 10, by konc
starquake wrote:
Could you explain how it could be dangerous when copy pasting CHS values? Would like to know.
Nothing will explode 🤣 Auto-detecting a card on a PC supporting LARGE/LBA might give you wrong values for a pure CHS-capable BIOS. To be honest smaller cards mostly come out correct, but larger and newer CFs sometimes return very weird geometry, nothing like a mechanical disk. There's no problem with this approach, you just need to understand what values you're getting and if they make any sense. I mean you may end up with values that are even outside the range of what you can enter on a CHS-only BIOS.
Reply 6 of 10, by kixs
If your BIOS supports LBA, then I'm almost certain that it has HDD auto detect. Just use it. With CF larger then 1GB use LBA, otherwise use CHS.
Reply 7 of 10, by starquake
I was talking about the same scenario that the OP was talking about. Using autodetected CHS values for a machine that does not do autodetection.
In other words: I'm safe using the autodetected CHS values (not LBA or LARGE) in a machine that does not have autodetection, right?
EDIT: OP was not talking about doing that. Disregard that statement.
Reply 8 of 10, by konc
Yes, that's what I meant by "understand what you're doing". If you can do an auto-detect and force CHS, of course go ahead and do it, it's all good. Not all BIOS however allow you to choose mode (CHS/LARGE/LBA) when using auto-detect, that's why I made that comment -but obviously didn't explain it enough.
@kixs: starquake is not the OP 😉
Reply 9 of 10, by root42
Wow, thanks! The IDEINFO.EXE worked! I had been struggling to get the geometry for a 256MB card. Since I don't have a regular PC anymore, this was the only way on my 286. 😀
YouTube and Bonus
