First post, by Razor655
Is there a command line utility similar to hdparm avaible for DOS?
I already know that Victoria for DOS ( ftp://ra.afraid.org/pub/dos/victoria/vcr352.zip -- freeware ) can adjust APM values. But I need to run it manually everytime I turning on PC which is little bit boring. I need something that I can put in autoexec.bat and forget about it. 😀
- C&C: Red Alert Archive project
QDI Titanium IIB / P55C-200 / 64Mb RAM / 8Gb IDE CF / ATi 3D Rage Pro 8Mb / Sound Blaster CT2890 / 3D Blaster CT6670
Reply 2 of 2, by kaputnik
If it's a Western Digital drive, you could always try wdidle3. It sets the idle timeout on firmware level, so if it works with your specific drive, you won't have to run anything from the OS.
Seems wdidle3 isn't available from WD's site anymore, so attached it for you in case you got a WD drive and want to try it.
    wdidle3_1_05.zip
    170.41 KiB
    42 downloads
